  3. Create or Update netrev failed, not updating netrev
  • Views 19625
Vikas Dabas
Vikas Dabas over 10 years ago
i have made netlist without errors, I wants to update the netlist of board file that i'm using now. i mean it is open.
Now i select the create and update board netrev, but it it opens new board rather than updating the same board.
 i have tried do not open board file, but it is still not updating the board that is open now and in use.
Thanks.
Vikas Dabas
  • oldmouldy
    oldmouldy over 10 years ago
    If you have the "target" board open in PCB Editor, it will have a lock file associated with it and won't be updated, check the Session Log messages. Close PCB Editor and then run the Uprev process again from Capture / CIS.
  • Vikas Dabas
    i have changed the setting of lock file from user preference. it no longer creates lock file. but still not updating
  • steve
    steve over 10 years ago
    As oldmouldy says you MUST close PCB Editor for it to be updated..............
  • Vikas Dabas
    but if we remove lock we not need to close the file. it opens new pcb editor with old one still opens.
    what i wants is like layout software, to update netlist in realtime rather than close and open again. its better to import the netlist than close the pcb and open it again. i have created the automated file to import netlist via commands/script file. but still if there is any way we can do it automatically without closing the pcb.
    Why not add this feature rather than discussing the alternatives of importing netlist. Please forword this feature as you are oldies in this field, and you may have contacts.
  • steve
    The only option you have is to uncheck the Netrev when you create the netlist then once it's generated go to PCB Editor and use File - Import - Logic (or Import - Netlist in SPB16.6-2015) and browse for the allegro folder and import the netlist that way. At least you can leave PCB Editor open...
