  3. Snake mode disable
  • Subscribers 166
  • Views 16309
Snake mode disable
redwire
redwire over 9 years ago
Hi
I'm evaluating 16.6-2015 and am playing with snake mode.  I found that once I select it during a route any further routing that is not dangling won't start routing.  I get an error message in the command window saying that the line must be dangling.
Got it.  Now how do you turn it off without clicking on a dangling route?  The only method I have found is to create a dangle and then RMB->Snake off
Is there a way to kick off snake mode through another menu?
Bill
  • steve
    steve over 9 years ago
    Snake Mode should just "work" when inside a pin field. If your routing in snake mode then click to exit snake mode you should route "normally" until you enter another pin field when snake mode enables again.
  • pcbideaguy
    pcbideaguy over 9 years ago
    That was certainly not the behavior I experienced.  Once I turned it on it was sticky and didn't care about pin-fields.  The only way to disable was to find another dangle and rmb->deselect.  Strange.  But I decided against the upgrade and it's no longer a issue.  Thanks for the comments.
  • steve
    Shame you didn't take the update, depending on the license level you have there are many new features (apart from Snake Mode)....
  • redwire
    Hmmm...I tried to extract from EMA what *enhancements* I was getting from my Performance L license. The "equivalent" OrCAD Pro seemed to be only taking away features and the others I won't use. I'd love to hear if there's something useful that I missed
  • steve
    Take a look at the pdf. http://www.parallel-systems.co.uk/e-mail/PCB_Suites-MATRIX.pdf It has a "New in 2015" which should give you a clue. The Performance L (which is now Allegro PCB Designer) is the third column.
