  3. Diff pair gap report
  • Replies 12
  • Subscribers 166
  • Views 16868
Manikandan Mal
Manikandan Mal over 9 years ago
My PCB file is not responding, while genarating Diff pair gap report from Allegro-Tools-Qick report. But other PCB files are opening immediately.How to get my Diff pair gap report?
Mani
  • steve
    steve over 9 years ago
    Does the command line report anything ?
  • Manikandan Mal
    No. I didnt used command line report. i tried using tools -Quick report. If you know any command line report. please let me know. i will try that.
  • steve
    Read my post carefully - Allegro has a Command Window at the bottom of the screen where you can type commands but the tool also may list any errors etc at this location. When you run the report does it say anything here ? Can you also try running "other" reports on the same board file ?
  • Manikandan Mal
    No. I didnt see any details on command window at the bottom of the screen. if i genarate the same report from other PCB files, its shows the report immediately.
  • steve
    So on the board that doesn't work - can you run any other report from the Tools - Quick Reports menu like Summary Drawing report for example ?
