  3. Differential Pair
  • Subscribers 166
  • Views 14328
Differential Pair
gowthaman90d
gowthaman90d over 9 years ago
Hello all..I wonder why we need a reference plane or return plane for differential pairs?? I thought Trace 1 is reference for Trace 2 and vice versa..It is obvious that we must need a return path for single ended signals but why we need for Diff pairs..Experts pls clarify me..
Gowthaman D
  • tltoth
    tltoth over 9 years ago
    Where do you think the current returns to the source or where do the signal lines are referenced to? Just think about a differential amplifier i.e. an OpAmp. It has inverting and non-inverting inputs and GND or even VSS as well. In this case "Ground" can be virtual, but return path needed to reference your signal lines to.
    It is not a current loop but a voltage mode signal transmission.
    Hope this helps.
  • gowthaman90d
    Thank you Mr tltoth. I have been thinking it is a current loop. I understood your point. But I have another doubt regarding impedance of the diff pair. Impedance of a trace depends on the reference plane to my knowledge , I have been told from senior at my company..If we did not maintain the correct Primary gap of the differential pair, there will be mismatch in impedance irrespective of the reference plane. Is my doubt make any sense? if so pls clarifiy me on this..
  • tltoth
    There are lot of great books and articles out there, just google them.
    But in a nutshell the characteristic impedance depends on geometry and material properties.
    Whichever changes the impedance changes too.
  • redwire
    redwire over 9 years ago
    Imagine a twisted pair in free space.  Here the signals couple to each other and no reference plane is present.
    Now bring that pair close to a ground to which the signals are referenced.  Any stray coupling now can couple to the plane.
    Now untwist the pairs and attempt to keep the stray fields from coupling to the plane.  It won't happen.  This is the case you have with a differential pair on a PCB.  Remove any planes and you will have a given impedance.   Once you bring that pair close to a plane its differential impedance changes as the "mode" changes from differential to common mode.
    For most PCBs it is not necessary to "tightly" couple a differential pair.   You could route each half of the pair as a 50 ohm line and get a 100 ohm differential pair if the signals do not couple to each other -- but the signals would be referenced to the planes.
    But, based on physical geometries on PCBs it is often necessary to push signals close to each other to accomplish routing.  It is also necessary to have power planes for other signals.  So when all considerations are taken into account, a reference plane(s) is required and the "differential" pair must be adjusted to the proper width and spacing to accomplish a certain impedance.
    So to your original question, no it is not required in theory to have a plane to generate a differential pair but it is nearly impossible in a PCB to achieve this.  I think that is why you are being told to use a reference plane or planes.
  • gowthaman90d
    Thank you Redwire
