  3. Gerber does not agree with allegro dimension. Everything...
  • Replies 9
  • Subscribers 167
  • Views 15690
Gerber does not agree with allegro dimension. Everything is shifted
TiBo
TiBo over 9 years ago
I haven't seen this or ever been mentioned to me that the gerber does not agree with my allegro dimension.
Anybody sees this kind of problem before and what is your solution for this.
I have Allegro 16.6 - hotfix 67 which is the latest. I use CAM350 to verify the off set and the board vendor also told me so.
Thank in advance.
TiBo
  • TiBo
    Hi Steve, I did check the offset too, making sure something get changed by accident, they all 0,0. Thanks
  • oldmouldy
    oldmouldy over 9 years ago
    You could also check the Scale Factor for Output in the Parameters tab, a bit unlikely that you would have touched this though. A mix of metric / English units might be a consideration as well but unlikely...
  • TiBo
    Scale factor is 1, I always do my dimension in inches, the 0,0 origin is dead on the lower left corner. Thanks
  • TiBo
    Guys,
    I found out that the problem is not in Cadence, it is in CAM350 viewer.
    If I zoom way down on each point when I do measurement then the dimension match exactly what I have in Allegro.
    Like I said, I haven't have problem with this before and I don't use CAM350 to measure and verify anything.
    This time a board house in China told me my dimensions in Fabrication drawing are not matching with Gerber data and they use CAM350 and I see that when I zoom out and click on 2 points for measurement.
    Thank so much for all of your input and help.
    Best regards,
    TiBo
