  3. pspice smoke analysis
  • Views 13529
Ninja17
Ninja17 over 9 years ago
hi have built a citcuit in pspice a regulator circuit with pass transistors for more current i am using igbts but when i run a smoke analysis its tells me the max power dissipation is is to high for the igbt's but its only 24 watts when the max power disipation is 200 watts according to the datasheet but in the rated column is states it is rated at 3.669 watts so i went into the model editor and tried a few values in the power dissipation column and max juction temperature but that rated value would not change when i altered the parameters of the igbt so i don't know whats going on please could someone help i am desperate thanks
thanks for your help
  • oldmouldy
    oldmouldy over 9 years ago
    Do you think it likely that a stand alone component will dissipate 200W from it's package? I suspect not. Try looking at the Case / Ambient thermal resistance parameter, maybe you need to specify a value appropriate to your system, rather than relying the component in "open air" to dissipate all of the power.
  • Alok Tripathi
    Alok Tripathi over 9 years ago
    I tend to agree with Oldmouldy about the possible cause of derated power IGBT. One of the key feature of PSpice Smoke Analsis is it's built-in deration. It warns user about potential failure under current operating conditions.
    For semiconductor devices, Smoke derates the rated power as per junction temperature. Image shown below variation of rated power as per junction temperature.
    You may want to modify the "RCA" property on pass transistor. Value of this property should be as per heat sink thermal impedance. This property will simulate an associated "heat sink" with this device, thus bringing junction temperature down and making available higher rated power for device under operating condition. Hope this clarifies.
  • Ninja17
    thanks a lot guys but one thing alokt the image you refer to in the post i can not see it but other than that it was quite good but if i could see the image that would be great
  • Alok Tripathi
    Here is the image. I am not sure why this was stripped off from previous post.
    I would also encourage visiting and using forum (solely for PSpice users community)
