  3. Cannot find export->subdrawing in OrCAD PCB Editor 16.6
  • Views 3335
Allan M
Allan M over 9 years ago
Dear Cadence PCB Design Community,
I am trying to make a symbol out of the visible features on a complete board design (a plug-on daughter-board) so I can use it as a symbol in another board design.  I have been successful before but not now.  In earlier versions, I would edit the board, make the features I want visible and then export a subdrawing.  In 16.6, I am unable to find the menu selection that invokes this process.  As a workaround I did the following:
1. Edit the board as before, showing the features I want, such as connectors, mounting holes and certain component features.
2. Export as a DXF.
3. Import the DXF in a new symbol drawing and save as a mechanical symbol.
4. Export as a subdrawing in the symbol edit mode of Allegro.
I am confused.  The 16.6 menus in board mode seem to be different from the menus in symbol mode.  What am I doing wrong?
Thanks in advance,
Allan
  • Allan M
    I often ask a question and figure it out myself anyway. Exporting a subfile in older versions means exporting a "clipboard" file in newer versions. Both methods create a ".clp" file. This is a "gotcha" caused by unexpected changes to the user interface structure and terminology.
  • steve
    steve over 9 years ago
    Just as a FYI Cadence changed the menu structure when the 16.6-2015 release was issued for OrCAD PCB users. This new menu structure was intended to make the menus more intuitive for new users. For existing users that already know the default menus you can either learn the new menu structure or under the Display menu is a "use legacy menu" option which requires a restart which will return the menus to the ones you know. Just to confirm for other users the File - Export - Subdrawing command is now Export - Clipboard.
