  3. Unconnected Pins Report says through hole in pad not connected...
  • Subscribers 166
  • Views 14982
Unconnected Pins Report says through hole in pad not connected to plane
jmadsenee
jmadsenee over 8 years ago
I am using Orcad PCB Editor V17.2.  I have a symbol for a LFCSP with an exposed pad and the pad has 4 holes in it.  On the schematic, the pad is connected to ground, and it can be clearly seen it the 3D view that the holes are indeed there and connect to the ground plane.  However, the Unconnected Pins Report shows those pads as unconnected.  Viewing the rat, I see it going from the center of the pad to a nearby ground via.  Anyone have any thoughts?
Thanks!
  • oldmouldy
    oldmouldy over 8 years ago
    The report could well be correct. Which exact version? (17.2.s010 is the latest) Try a Check>Database Check with all the options enabled (Tools>Database Check for the legacy menus). Zip and attach the board file as a last resort.
  • jmadsenee
    Hi oldmouldy, thanks for the reply.  I am using 17.2.s001.  I tried the database check, but to no avail...  In the zip file is a snip of the 3D view showing the holes connecting to the ground plane, same as the via in the lower left corner...
     ViaInPad.zip
  • KeithP
    KeithP over 8 years ago
    It does not get connected because you do not have a Regular Pad feature on the internal layers
  • jmadsenee
    Hmmm... I thought I had tried that - I modified the padstack to define the Default Internal pad, then updated the symbol... I must not have refreshed the padstack...
    Thank you so much for your help!
