  3. Allegro 16.6 "Marked Fanouts" disappear after eco proce...
  • Views 617
Allegro 16.6 "Marked Fanouts" disappear after eco process
55STRAT
55STRAT over 8 years ago
All, I have capacitors, resistors fanned out and tied to symbol (MARKED) for ease of Move/Routing.
I need to change parts with same footprint. After I import Logic, the "Marked" fanouts go away.
I can "Unmark" the offending fanouts, then run and all is well. Unfortunately, this is NOT the solution we are looking for.
Any ideas would be appreciated. TIA, Patrick
  • steve
    steve over 8 years ago
    Check the exact version you are running from Help - About. If it says 16.6 P00X then this is more than likely the base release and the cause of the problem. Get the latest hotfix from Cadence online support. The latest hotfix is S086.
