  3. 3D Step file creation in Allegro?
  • Replies 8
  • Subscribers 167
  • Views 17217
sdettwiler
sdettwiler over 8 years ago
Is there a way to create a 3D part step file in Allegro during a part creation?
If relying on other software tools is required then when will this feature be incorporated?
Thank you-
  • redwire
    redwire over 8 years ago
    Allegro will use the place bounds to create the STEP file if an actual STEP file is not used.  This is what I would call "Lego" blocks.
    Any detailed type of STEP with pins/plastic/metal is not possible thru Allegro.  However if you detail your placebound correctly you can get a reasonable model.
    This has been available since (I think...) hotfix 50 of 16.5 release.
  • sdettwiler
    Thank you and that is what I have noticed.  I am using another tool for the .step function when creating the component.  BTW have you been able to see the silk screen when in 3D?
    I am using both 16.6 and 17.2 and do not see any silk screen in 3D.  When I see the awesome 3D and mechanical drawings in Altium, I think..why not Allegro.
    Thank you
  • Wild
    Wild over 8 years ago
    I know this does not answer your question but here's a great resource:
    http://www.3dcontentcentral.com
    There are many models there that can be downloaded in various formats.
  • redwire
    No silkscreen -- that too me is a ding against Cadence's implementation of 3D view. I too have Altium and prefer its 3D viewing and export way over Allegro.
  • KeithP
    KeithP over 8 years ago
    Silkscreen display is there as of hotfix 16
