  3. library builder 17.2: how to bilid a NON-PLATED HOLE
  • Views 13831
ColinLiu
ColinLiu over 8 years ago
Hi friends,
Some of connectors has one or two plastic pitch pin which has not any eletrical property. it should be as NON-PLATED HOLE in PCB. But I can not find how to implement this at library builder.
All the PINS export by Library builder seems as PLATED PIN. Any method to achieve this?
  • steve
    steve over 8 years ago
    In Library builder there is an icon for a padtool so choose Padstack Calculator - Variant so select this and make a non plated variant of the padstack you want. You can then replace the pad you have with this variant.
  • ColinLiu
    Thanks for your reply, Steve.
    I have try this in padstack calculator, BUT it seems there is no icon/setting for NON-PLATED HOLE.
    I just try to adjust annular ring to 0 which does not make sense.  I think it should be ok if i build a NON-PLATED HOLE in PCB Editor/PADSTACK
    EDITOR in advance and then replace the pad using padtool-->replacement.
    While I think you mean i can make it using padstack calculator directly. Is it right? could you please help to point  it out?
  • steve
    Currently the only option you have is to edit the padstack once it's in PCB Editor and change it from a PTH type hole to a Mechanical one then set it as Non-plated. Cadence have plans to address this at the next release of Library builder though.
  • ColinLiu
    Got it. Thanks Steve.
