  3. How to restore "old" Junction behavior?
  • Views 1873
redwire
redwire over 8 years ago
HI
In pre 16.6 versions of OrCAD it was possible to break up a wire by placing junctions along the wire and then deleting the intermediate segment that was created.  Now that behavior does not exist in the default install of OrCAD.
I did notice that there is a variable in the CAPTURE.INI file called "JunctionMode" which I suspect controls this behavior -- however I have no clue what values it can take.
Is there a way to restore the old Junction behavior (pre 16.6)?
Bill
  • oldmouldy
    oldmouldy over 8 years ago
    You don't need to guess the values, you can set the option in Extended Preferences, a TCL Utility in 16.6, Accessories>Cadence Tcl / Tk Utilities>Utilities, Extended Preferences, Launch, Schematic group, Junction Mode (you need a design, or design page, open to get the menu, or Options>Preferences, More Preferences, Schematic group, Junction Mode in 17.2.
  • redwire
    Unfortunately that does not address the original question.  Those modes do not change the behavior that used to exist.
