  3. Adding Multiple values to single field in CIS database
  • Replies 7
  • Views 16068
nandikkara
nandikkara over 7 years ago
I'm Using excel as my part database. I have to add two manufacturer part numbers in a single field named "MFGP/N". So When I try to place the symbol, I can choose which part number need to give like selecting one from multiple symbols. Is there any possiblitity to do so?
  • oldmouldy
    oldmouldy over 7 years ago
    Yes, you can add multiple values to a field by adding values separated by the "Delimiter for Multi-Values" set in the CIS Configuration, Administrative Preferences, default is comma. Note that multiple values for the CIS database required fields, mapped to: Part Number, Part Type, Value and Schematic Part, are not supported.
  • nandikkara
    nandikkara over 7 years ago in reply to oldmouldy
    Here also delimitter is comma, But no use please see the figures.
    1. It is coming in CIS like this, no dropdown box,
    CIS
    2. Delimiter
    3. type shown in table. it is not the required field
  • oldmouldy
    oldmouldy over 7 years ago in reply to nandikkara
    The Manufacturer Part Number is reserved for the obsolete ICA fields, you probably need to have a table field named MFGP/N, or something like that, for this to work. No spaces between the alternatives would also be recommended. And you haven't mentioned which exact version you are running.
  • nandikkara
    Im using orcad CIS 17.2. Its not working for other fileds also. Any thing need to set at the time of adding fields?
  • oldmouldy
    There have been a number of updates since the initial Base Release of 17.2 so "simply" OrCAD CIS 17.2 is hardly the "exact version", current version is 17.2-2016.s035 and the multi-value seems to be working fine for me.
