  3. Cadence Allegro 17.2 - Shape to board outline clearances...
  • Subscribers 162
  • Views 5308
ChrisTait
ChrisTait over 8 years ago
Hello all,
I hope you can help, I have different requirements for clearances to the board edge which I want to enforce.
For example one net can have copper 2mm from the board edge whilst another has to be 4mm away.
How can I control this automatically in Allegro ?.
At the moment I have two draft lines which I follow manually, I'd like Allegro to do this... and DRC !.
Thanks for your time,
Chris
  • ChrisTait
    ChrisTait over 7 years ago
    No replies at all !, I guess I must have really asked a stupid basic question.... I will have to hope I find the solution myself.
    .... otherwise, it's not possible... or I wrote the question badly.
    Chris
  • excellon1
    excellon1 over 7 years ago in reply to ChrisTait
    Not a stupid question. Chris I think you are asking is there a method to selectively "Based on net type" apply a rule to a shape so that each shape could have a different clearance from a board outline. or keepout etc, Is that correct ?
    Paul.
  • ChrisTait
    ChrisTait over 7 years ago in reply to excellon1
    Thanks Paul,
    Basically yes..... I need for example NET 1 to respect a clearance of 1MM to the board each and NET 2 to respect 4MM to the board edge.
    I was hoping to just throw a shape at the board and Allegro to apply automatically a clearance, I come from over 8 years with Altium..
    IF IsBoard AND isLine AND isNET2 .... clearance =4mm (simplied example), with this Altium would backoff the board outline automatically.
    In Cadence, I am basically adding a shape and manually making sure it is backed off by the 4MM.
    Just wondering if Cadence can do something automatically... the more I write this, the more I am thinking it doesn't...
    ... but thanks for the reply Paul !,
    Chris
  • redwire
    redwire over 7 years ago in reply to ChrisTait
    Hi Chris -- I just saw your post so sorry for being late.  I have never done a specific rule and always controlled this manually as you have done.  However, after thinking about it I came up with a way albeit a little cryptic.
    If you draw a 0 width line on the plane layers, you can set a rule to offset a shape from a line by xxx mils/mm on a specific layer.  Then you could adjust the offset in Constraint Manager if the shape is dynamic.
    Allegro does not differentiate line types as Altium does.  So the downside to the approach I have presented is that *all* lines on that layer will follow that rule.
    I have attached a sample 6 layer board that incorporates this offset rule.  I'm not sure what license level you have but I would hope it works at all license levels.
    Bill6L_test.zip
