  3. How to export logic from PCB editor?
  • Views 17237
zfan
zfan over 7 years ago
Title says.
Is there anyway I can visually see the logic of a board file? I'm using a generated netlist to feed PCB editor but no design file. A pity to be sure that I can't export .brd into capture
  • redwire
    redwire over 7 years ago
    Yes...there are several methods.  What style netlist do you want to see?  The "internal" version that Cadence has been using since it was Valid is the de-facto version used between both Concept and Capture.  However, try Export->Logic and the old school "Telesis" format which is ASCII is generated.
  • zfan
    zfan over 7 years ago in reply to redwire
    Thanks for the reply! But somehow I can't find the option to export telesis in Orcad PCB 17.2
  • zfan
    and what I really need is to extract logic from existing .brd or netlist files "pstchip.dat","pstxprt.dat" and "pstxnet.dat". Board file shows chips but can I see a view of gate level?
  • oldmouldy
    oldmouldy over 7 years ago in reply to zfan
    You need Export>More>Netlist w/Properties using the OrCAD menus. That will get you a "third-party" netlist, that will be a list of Packages and Connections, Device Files will be required to reuse the third-party netlist, you can create those from File>Export>Libraries (Export>More>Libraries from the OrCAD menus)
