  3. New File...Open Dialog Box?
  • Replies 8
  • Views 17114
Tmills
Tmills over 7 years ago
Hey guys...I searched the forum and came up empty. If this has been discussed and answered before, please, be gentle. Slight smile
I am running v17.2 S048 and have new dialog boxes. The one in particular that gives me trouble is the File..Open dialog. It now no longer seems to be a Win10 dialog box, instead it seems to be an Allegro specific dialog box.
New v17.2 S048 File...Open Dialog
The old dialog box looked like this:
This gives me trouble because many of my designs reside on network servers and are not easy to access anymore. Plus, it just looks wonky and I don't like it! Disappointed
Is this a simple setting change or is this the new normal?
Tom
  • eDave
    eDave over 7 years ago
    The old file browser window can be restored by setting the environmental variable "new_filedialog_disable". The variable can be can set in the env file and is currently not available in User Preferences within the tool. To set the variable in env file, open the file with any text editor and add the following line at the end:
    set new_filedialog_disable
  • Tmills
    Tmills over 7 years ago in reply to eDave
    PERFECT!!! Thanks so much eDave!
    Cheers! Beers
  • eDave
    eDave over 7 years ago in reply to Tmills
    Note that you will lose the rather nice preview feature of the new file browser if you revert. You might like to try with the new browser for a while to see if you can get used to it.
    • Vote Up +2 Vote Down
  • oldmouldy
    oldmouldy over 7 years ago in reply to Tmills
    In the new File>Open dialog, you can also drag folders from the "View" box on the right into the "Look in" list. This is more flexible than offered by the regular Windows version.
  • B Bruekers
    B Bruekers over 7 years ago in reply to eDave
    About the nice preview, yes it is a nice improvement but it is slow with large (>30MB) designs. The old preview is much faster and normally sufficient to browse through a list of designs.
    Further, the new open dialog shows the mapped network drives incorrectly (HF48). How to tell which drive is which?
    Also the 'default windows' copy/paste, new folder etc is not working in the new windows.
    For now we stick with the old bowser and hopefully Cadence won't decide to remove the new_filedialog_disable option......
