  3. Hotfix S049 SHIFT arrow keys moving symbol by grid settings...
  • Views 14270
Lennie
Lennie over 6 years ago
It seems that any of the arrow combinations with the shift key no longer move the symbol by the grid settings. Anyone else see this ?
  • excellon1
    excellon1 over 6 years ago
    Lennie in HF049 they are broken. The issue I found is that it is related to a UI setting. I had reported a few days ago a problem with hot keys. Steve had the fix..
    try the following.
    Go into your user preferences. Under UI > General > "Un check enable command window history" Not sure if you are on HF049 but I confirmed that on HF049 and if that UI preference is enabled then the arrow keys wont work.
  • Lennie
    Lennie over 6 years ago in reply to excellon1
    Thanks that fixed that problem. Now if I can get the full cursor disappearing during the drag operation and the focus to change from the options screen back to the canvas correctly like it used to work I would be happy.
  • Robert Finley
    Robert Finley over 6 years ago in reply to Lennie
    Lennie, just curious, are you running on a laptop?
  • Lennie
    Lennie over 6 years ago in reply to Robert Finley
    No. All these items have to do with 17.2. They all worked fine with 16.6.  They fixed some of keyboard / focus problems from a CCR that I created  early on but not all of them. The latest Hot fix broke them again.
  • excellon1
    excellon1 over 6 years ago in reply to Lennie
    Lennie on the cursor, I did a re-install recently. The FSC cursor was broken in S038 or before it. SO38 was the oldest SP I had to hand. As a matter of interest, do you like that the side menus no longer slide out as they did in 16x ?. I kind of liked how they auto collapsed to free up screen real-estate while editing. Operations seem quicker to me in 16x with the auto slide out Options, View panel etc.
