  3. Problem with "cross-section" command
  • Replies 8
  • Subscribers 166
  • Views 5729
KobiC
KobiC over 6 years ago
Hi All,
I am an Allegro PCB beginner and I am working now on a new layout (version 16.6).
After defining the stack up at the beginning of the layout, placing all the parts and routes, I wanted to remove 1 layer.
For that, I've tried to enter the Xsection area, but when pushing the button, nothing happens: in the commands window the following is shown:
Loading cmds.cxt
Loading floor.cxt
Loading skillExt.cxt
Loading axlcore.cxt
Command >
However the expected cross section window is not coming up.
I'm working with 2 screens, tried to look for it at both.
Thanks.
  • CadAce2K
    CadAce2K over 6 years ago in reply to KobiC
    If you type %HOME% and carriage return in any Explorer (e.g. folder explorer) it will take you to your 'Home' folder. In there you'll find the 'pcbenv' folder as Steve recommended.
  • KobiC
    KobiC over 6 years ago in reply to CadAce2K
    Thanks you both, it worked.
  • KobiC
    KobiC over 6 years ago in reply to Ummer
    Thanks, it works.
