  3. redundant constraints
  • Replies 10
  • Views 16656
Lock2002
Lock2002 over 6 years ago
Is there any way to delete redundant  spacing constraints in Allegro? They are all repeated with the exception of same to same, eg, Thru Pin to Thru Via and Thru Via to Thru Pin. They can also have different values, which doesn't make any sense. I assume it uses the smallest value.
  • steve
    steve over 6 years ago
    Try a Tools - Database Check, there is an option to purge unused constraints
  • Lock2002
    Lock2002 over 6 years ago in reply to steve
    that doesn't resolve the redundant constraint issue.
  • steve
    steve over 6 years ago in reply to Lock2002
    Can you post a screenshot of CM to clarify what you are trying to remove?
  • Lock2002
  • redwire
    redwire over 6 years ago in reply to Lock2002
    You didn't screen-grab the whole screen so I am guessing you are looking at the nets spacing vs the top-level spacing rules.  Nets can be overridden and inherit the top level constraints or as shown in the far left column you can apply a specific constraint definition instead of "DEFAULT".   If this is not the nets spacing display then please post a full screen-shot.
