  3. Exporting 3d step file from database crashes program
  • Subscribers 166
  • Views 15269
HSID
HSID over 6 years ago
When I try to export out the .stp file from pcb layout the system will eventually crash due to the size of the database.
Is there anything I can do. This .stp file is what we  give to our mechanical group to put into their model for checking mechanical interferences, etc.
  • CadAce2K
    CadAce2K over 6 years ago
    Hi. You might try simple stuff first. I'll assume you're trying to STEP EXPORT the whole design. Keep it simple, and add more to it if mechanical needs stuff. (e.g. I've tested it quite a bit to get what my ME wanted. He was asking for the whole design so he could review it in Solidworks. I trained him in Allegro Free Viewer instead.)
  • Dale Peterson
    Dale Peterson over 6 years ago
    Just adding to CADAce2K's comments. Turn off everything in the "visibility window" except "Dielectric" as well. The only time to render everything, is when someone needs a pretty picture of your design to paste into a presentation of sorts. In this case a screen capture would do.
  • HSID
    HSID over 6 years ago in reply to CadAce2K
    Thanks, our ME group needs the step file so they can import it into their Solidworks model. I try exporting out from 3d Canvas as well as the database. 3d Canvas has a much larger file when creating from there, not sure why I only have the basic items selected.
  • HSID
    HSID over 6 years ago in reply to Dale Peterson
    Yes, I have tried whaty you suggest and still the file is large. Will need to reach out to Cadence again and see if they have a solution now. Thanks
  • Dale Peterson
    Dale Peterson over 6 years ago in reply to HSID
    Yes, file sizes are still too big in my onion as well. Smaller yes but still too big. If you are going to reach out to Cadence. Try to get them to build an output option that would distill down the design to a single model surface. A feature that is in Solid Works I believe. Rather than a bunch of separate parts which drives the ME's crazy. A single model would be much smaller in size. Good luck!
