  3. PCB Land pattern with multiple shapes
  • Views 15916
Frozen001
Frozen001 over 7 years ago
I am trying to make a PCB land pattern for an RF shield that is mounted using special clips.
the clips are here:
https://hollandshielding.com/PCB-shield-mounting-Ultra-tiny-clip-UTC
https://hollandshielding.com/PCB-shield-mounting-Ultra-tiny-corner-clip-UTCC
I originally figured I could just create a custom symbol for the land pattern, but that does not work as you can only have one shape.  Ideally, I want a footprint that has the 4 corner clip patterns and the straight patterns all in one footprint that only has to have one pin in the schematic to ties those to ground.
Any thoughts on how to best do this?  I also need to have the keep outs in specific areas near the clips and where the shield would be near the PCB.
  • steve
    steve over 7 years ago
    If you don't need to connect to it (and will rely on the part making contact to the three pads) you can either make these mechanical pins so you then only have one pin the schematic. You can also place one pin down in a package symbol and then draw copper shapes for the other sections. Keepout areas can be drawn in the package symbol.
  • Frozen001
    Frozen001 over 7 years ago in reply to steve
    Thanks for the input.  I think because I want them all connected to ground I may just run a small slice of copper to connect them all and call it a day.  That way it technically is "one" shape, but still has the distinct shape needed to match the recommended land pattern.
  • RFinley
    RFinley over 7 years ago
    Because this is multiple clip parts available on tape-n-reel, for pick-n-place programming and BOM exports, there are advantages to adding the clips as individual components.
    Yeah, schematic ugly, really don't care.  I use mechanical symbols that puts the outline of the shield on the Board/AssemblyNotes subclass to verify clips placement.
    Otherwise, armed with only the center point of the shield, the assembly programmer may have to manually add the coordinates of each clip by hand and you will have to make the BOM work out.   As the guy who did that 20 years ago, buy him lunch first.
