  3. DRC error: route keepout spacing
  • Subscribers 166
  • Views 16348
masamasa
masamasa over 6 years ago
hello
i have a route keepout spacing error.
i do know that i can allow "vias", "routes" (clines), "pins" and "shapes" in the keepout shape area by changing the shape properties.
but i get this "line to keepout spacing" error as i place a text into a keepout area.
is there any way to allow a text or a line into a keepout shape area by changing the shape properties?
  • steve
    steve over 6 years ago
    The only option I believe you have Is to manually void the text so draw a void inside the shape to clear the text.
  • masamasa
    masamasa over 6 years ago in reply to steve
    thank you for your advice.
    based on your advice, i voided the text from the shape by exporting the text gerber out, outlining the text lines and imported the outer lines into pcb editor.
    thank you again, steve
