  3. who does SI/PI simulations? the hw engineer or the layout...
  • Replies 7
  • Subscribers 163
  • Views 4392
who does SI/PI simulations? the hw engineer or the layout designer?
archive over 17 years ago
hi.
who does SI/PI simulations: hw engineer or layout designer?  if there is no SI engineer.
do all companies use the allegro simulation capabilities? (at least reflection analysis)
and anyway, how much control does the hardware engineer have over the layout:
can he say to the layout engineer this?-"put these 10 capacitors here and not there" or "put the termination here" or "make this splitplane wider"...
who specifies the layer stackup, materials, trace widths, footprint assigments, bus-layer assigments...
Originally posted in cdnusers.org by buenos
    In general, the PCB layout person does not have the background to be able to do the SI/PI simulations. Some companies or departments simulate, some don't. More of them should. The H/W engineer has significant control over placement but it is a balance between mechanical, thermal, ease of routing, I/O locations, etc. It is usually a team effort. The first placement is sometimes done using post-IT notes on a piece of cardboard. Location of terminations is driven by signal integrity considerations.
    Stackup, trace widths, and dielectric material are a balance between cost, impedance requirements, routing difficulty, emi/noise requirements, how many DC voltage planes are needed, etc.
    It sounds like you are new to the hardware design process. Spend some time talking to an experienced hardware designer.
    Originally posted in cdnusers.org by Kalevi2
    thanx the answer.
    i am not new to hardware development, but I was working in an unusual way until now, but I want to change to another company. Most of them work in the usual way, which is new for me. Until now, I was doing everything, and its not clear for me, what tasks will remain for me, and what will not.
    and who does the schematics-level design and assigning footprints to schematics-symbols?
    (I hope not the layout designer, but the HW design engineer.)
    everywhere?
    The design engineer is supposed to do the schematic level design and a CAD librarian does the footprints. If you are a small outfit, the layout guy probably is the librarian and does the footprints.
    thanx again.
