  3. Placing and routing identical circuits in PCB
  • Replies 7
  • Views 17055
Santosh Vema
Santosh Vema over 6 years ago
I'm using OrCAD PCB Designer Standard version 17.2-2016 S056.
I have few identical circuits that need to be placed and routed in a similar fashion.
Lets say I placed and routed one group of components and I want the second group of components to be placed/routed in the exact same manner.
Groups have same number of components.
Santosh
  • CadAce2K
    CadAce2K over 6 years ago
    It's called 'Place replicate' -
    1) Go into PLACEMENT MODE
    2) Select some components; RMB (right mouse button) and click on 'place replicate create'
    3) select any additional elements (vias, clines, etc.) you wish to replicate (see your console/session log on the screen)
    4) RMB DONE when complete
    5) Name the circuit replicate group
    FYI - all components have to be place somewhere in your board file to make this work (I place them with 'Quick place')
    6) RMB; Place replicate (the other, not the create)
    7) Options tab ; set your replicate options
    8) place the circuit using a grid, an X-Y location, etc.
    Complete. There's a online tutorial I'll post.
  • CadAce2K
    CadAce2K over 6 years ago in reply to CadAce2K
    support.cadence.com/.../
  • Santosh Vema
    Santosh Vema over 6 years ago in reply to CadAce2K
    I clicked on Placement Edit button (Setup->Application Mode->Placement Mode). When I selected few components, I don't see Place Replicate Create. I read in another forum that these options are only available in Professional version of PCB editor, I have a Standard version.
  • masamasa
    masamasa over 6 years ago in reply to Santosh Vema
    i do not have a professional version either.
    so what i usually do is to export the routing and components (vias, clines, shapes, and symbols) as a sub-drawing and then import the sub-drawing back to the same file at a different location.
  • Santosh Vema
    Santosh Vema over 6 years ago in reply to masamasa
    Thank you, I don't see sub-drawing in version 17.2, but i think its Export->Clipboard and Import->Clipboard?. Once I did that all the refdes are reset to '*', so you then change the refdes of each component?
