  3. unassigned nets
  • Subscribers 166
  • Views 14257
unassigned nets
masamasa
masamasa over 5 years ago
hello
is there a way to remove all unassigned nets at once from the design file?
i do know i can remove an unassigned net one by one.
but i would like to be able to remove them all at once like purging all unused padstacks.
  • kannan sai
    kannan sai over 5 years ago
    Please create a text file as below
    $nets
    $delete
    Net1
    Net2
    $end
    Then in pcb editor , select File-Import-logic and select the text file(which you have created to delete net).The unassigned nets will be deleted & check status for no of net deleted with previous brd.
  • masamasa
    masamasa over 5 years ago in reply to kannan sai
    hello
    thank you for your reply.
    your method works.
    but in order to create a text file with the delete section, i would need to list up all the unassigned nets.
    i have over 100 unassigned nets in my design file.
    is there any way to list up all the unassigned nets?
    a net list report does not show unassigned nets.
  • kannan sai
    kannan sai over 5 years ago in reply to masamasa
    Go to Tools--quick report -- Net single pin and no pin report
    It will list out the unassigned nets in your design.
    Hope this helps..
    Cheers..!!
  • masamasa
    wow, thank you.
    i was able to get the report.
    thank you again.
