  3. Chip on Board (COB) in Allegro PCB Editor 17.2
  • Subscribers 166
  • Views 14668
J Rajesh
J Rajesh over 5 years ago
Any one used on COB technology in Allegro PCB Editor 17.2
I just need to know the challenges faced due to limitation in Allegro PCB Editor 17.2 compared to SiP.
Rajesh
  • RFinley
    RFinley over 5 years ago
    I've built about 20 substrates in Allegro, 3 in SiP.   Not an expert in SiP.
    Creating a footprint for a substrate in Allegro, I have to import GDS from Virtuoso, export DXF, mirror the DXF in AutoCAD, then import DXF back into Cadence to build that footprint.
    Allegro substrates have to be schematic netlist driven.  80% of my time goes to building the package footprint and the die footprint, then making an Orcad schematic (not worth the hassle to use HDL in a startup company.)
    Using SiP: import GDS, extract pin padstacks and pin names,  put it in the die manager face-up or face-down and there's your footprint.  Single GAN Dies for integrated PA modules with bias and filter.
    SiP included stacked Uvia and high-speed rule capabilities that are not part of the base PA-3100 allegro license that I have which helps justify it's cost.  A lot of time can be saved doing the design in SiP.
  • CadAce2K
    CadAce2K over 5 years ago
    Ditto what Robert mentions. Been doing COB (mainly unpackaged die on PCB) for some time. That's the easy part (mostly). Getting pitches routed at 0.35mm pitch or less is a problem - not for layout but manufacturing. We're getting into 2mil trace/space arena, and not many PCB houses can do it successfully (many like to try).
    For modules/interposer/etc. - Allegro PCB vs SIP? SIP has the methodology for doing them 'easier' but Allegro PCB can do them just as well. You just have to get used to what Allegro PCB wants. If you're used to vias as a build-up process then it takes a bit getting used to doing it in Allegro PCB.
    The leading argument for using SIP rather than Allegro PCB is your fabricators. If they prefer a SIP file for their verification/validation... well you'll just have to decide.
    Me personally, I'd much rather do these in SIP, and it's easy to learn. It's just that SIP is another EXPENSIVE tool for your arsenal. If you have Allegro PCB, normally you won't also have SIP.
    Strickly for plain-Jane modules/interposers though Allegro PCB handles them quite well. And easy.
  • RFinley
    RFinley over 5 years ago in reply to CadAce2K
    Yep, If you and your partner have SiP, do it there.  Our partner overseas did not have access to Allegro.
