  3. 17.4 - HF007 - Disable Capture StartPage...
  • Views 4755
UlfK
UlfK over 5 years ago
Previously, there was a way to disable the startpage by adding
[Start Page]
EnableStartPage=False
in the file spinfo.ini but in spite of this the start page is displayed in HF007. Any other way to disable it now?
  • mcatramb91
    mcatramb91 over 5 years ago
    No sure about spinfo.ini but the Start Page could be disabled by setting ALLEGRO_NO_STARTPAGE under UI > Startpage category in User Preferences.  It could be manually entered in the PCBENV/ENV file as well.
  • UlfK
    UlfK over 5 years ago in reply to mcatramb91
    That's for Allegro (PCB Editor) And that setting is OK - No start page there.
    My question was about Capture Schematic Editor.
    Previously, there was a check-box "Do not show start page" or something similar when invoking the schematic editor. Then that parameter was listed in advanced options (or the other way around) and then a line in spinfo.ini and now the setting is gone altogether...
  • Tinkerman
    Tinkerman over 5 years ago
    Go to Cadence\SPB_17.4\tools\capture\tclscripts\capAutoLoad and open capOrCADStartPage.tcl
    At the beginning change "set spRegEnvOpen true" to "set spRegEnvOpen false.
    This is the only working solution for HF007 now.
  • MrSpock
    MrSpock over 5 years ago in reply to Tinkerman
    Just tried this and its working on 17.4-2009 S007.  Thanks for your posting.
  • Tinkerman
    Tinkerman over 5 years ago in reply to MrSpock
    By the way, I have found a bit easier solution. Just create system variable called ENABLE_NEW_STARTPAGE and set it to false. No need to modify tcl file.
    But I can't figure out why capture lags on my Win7Pro. 17.2 was way more fast!
