  3. "Tips from Cadence" old style reports
  • Subscribers 163
  • Views 2027
archive over 21 years ago
You will notice that Tools-Reports has changed to a new HTML format with the SPB15.2 release. Many users have developed programs that rely on the output from the old style reports previous to this release.
The old style reports you are used to are still accessible from the allegro command by typing...
[b]old_reports[/b]
This will bring up the old style GUI you are familiar with in pre SPB15.2 releases. You may assign this command to a function key if you would like and add it to your env file as an alias such as
alias F9 old_reports
Additionally, please note the following...
You must set the allegro environment variable
allegro_old_report using
set allegro_old_report
in your env file. The setting must be in your env file. Once this variable is set, restart Allegro. Then on the Allegro command line type ""old_reports"" or select
your aliased function key to invoke the old GUI.
This feature is intended as a migration aid only in the 15.2 release and will be removed in later releases, so make sure to plan ahead.
Message was edited by: osprey
Originally posted in cdnusers.org by osprey
    There is a setting in User_Preferences under ""Misc"": allegro_old_report [ ]. Checking this box should result in old reports style, but it does not seem to work. At least not for the Summary Drawings Report.
    Thanks for the tip.
    Originally posted in cdnusers.org by Ulf Kylenfall
    Once this variable is set, restart Allegro. Then on the Allegro command line type ""old_reports"" to invoke the old GUI.
    Originally posted in cdnusers.org by Padmin
    Thanx for the additional information. I will add this to the original thread of the tip.
