  3. how to convert PADS layout into ORCAD layout
  • Subscribers 163
  • Views 17045
archive over 19 years ago
hello friends,
I am using PADS 2005 spac2 (from the mentor graphics)...   i want to convert the PCB layout of PADS to the ORCAD 9.1 layout ...  when we are exporting tthe pads layout its asking for a format in ASCII.. but i dont know which format will ORCAD 9.1 support .. so please help for converting the pads to the orcad 9.1 format..
thank you
Originally posted in cdnusers.org by azadi
    maybe you try another way. In Orcad Layout there is the option to import a layout generated by PADS PCB (File->Import->PADS PCB).
    Greetings,
    haikom
    Originally posted in cdnusers.org by haikom
    hi hakom,
    the problem is with ascii version i think, i dont know in which ascii format Orcad 9.1 support to import from a PADS spac2 version
    azadi
    The PADS to Layout translator supports PADS ascii upto version 2.1.
    Originally posted in cdnusers.org by rbennett
