  3. help on the Package Symbol wizard.
  • Views 13613
archive over 18 years ago
Hi I'm new to the allegro PCB editor and need to define some symbols for 1206 smd R's and C's.
Could do with some help when I get to the surface mount discrete parameters page, as to what exactly D, E and e1 actually refer to?
Originally posted in cdnusers.org by neil2007
    Upper case 'E' and 'D' refer to the package dimension of the part being stuffed in the board.
    'e1' is the center to center dimension between SMD pads. These corresponding numbers should be listed in the data sheet for your components. Alternatively, there is a library of parts supplied by Cadence in one of the install directories, I think it's ..\share\pcb\pcb_lib\symbols. I would advise checking them over to make sure they match required dimensions before using, though.
    Best of luck, newbie. We're here to help if you need it.
    Originally posted in cdnusers.org by annoonan
    Check out the web site www.pcblibraries.com. it has a free land pattern calculator that will help you to define the size of the pad and the spacing of the pads. it well worth the download, and for a small price you can get the allegro symbol generator.
    Originally posted in cdnusers.org by swilber
