  3. unconnected pins error
  • Subscribers 161
  • Views 16129
archive over 19 years ago
After migrating the design from protel(Altium) to Allegro 15.2, "unconnected pins report" showed 380 pins unconnected.Actually the pins were connected,but the clines did not snap to the middle of the pins.By re-connecting the two pins and check the "snap to connect point" box, the problem was solved. But there are too many errors like that, re-connecting all the pins cost too much time.Is there a way to set up Allegro properly and solve the errors all-together?
Thanks in advance.
HappySniper
Originally posted in cdnusers.org by HappySniper
    After doing the conversion, in Allegro run Tools > Derive Connectivity. That should snap all the endpoints to the appropriate pad/via locations.
    Originally posted in cdnusers.org by JBratton
    It works!
    Thank you so much!
    HappySniper
