  3. High speed DDR multi-tiered T routing
  • Subscribers 163
  • Views 14923
archive over 17 years ago
Hey all,
I'm trying to setup some matched length T routing for some high speed DDR memory. I have scheduled the nets properly with virtual pins and setup pin pairs in constraint manager under Relative Propagation Delay but I don't understand how to specify a length range for the individual pin pairs of the T route. Should this be setup somewhere besides Relative Prop Delay?
Image 1: multi-tiered T routing of DDR address buss. All segments A must match length. All segments B & C must match length. All segments D, E, F and G must match length. Data buss length must match address segment length to each DDR.
I'm running 15.5.1 with the performance option.
Any help would be appreciated....need to get moving on this board!!!!!
Originally posted in cdnusers.org by padmaster
    Relative propagation delay is the corect place for this constraint to live.
    There are acoupel of ways of getting the constraint into the field. The easiest to visualise is through sigexplorer.
    Open constraint manager, find a representitve net, right click it and open sig xp for that net.
    It's probably worth spending a few minutes at this point cleaning up the canvas, so that the tlines and receivers are layed out as per your diagram above.
    Now use the menu and open "constraints" Move to the relative propagation delay.
    Here you must create a pin pair and matched group name for each of the lengths that you wish to constrain.
    I looks like you are laying out data, so may I suggest:
    ("MGx" = matched group name)
    "MG1" pin pair defining D, scope local.
    "MG1" pin pair defining E, scope local.
    "MG1" pin pair defining F, scope local.
    "MG1" pin pair defining G, scope local.
    These will match D, E, F & G within each net.
    Then:
    "MG2" pin pair defining A+B+D, scope global (or bus).
    Which will match the length of D + E within this net, either to all nets upon which you apply this ECSet (global) or to all nets within the current bus (bus scope.) This is the matched group that is used to tie the 8 data bits together with the strobe in a DDR bus.
    Once the constraints are all set up, save the topology from sigxp and import it into constraint manager as an ECSet. Then apply the EC Set to your databus.
    If you don't have Sigxp, you can do the same thing from constraint manager, but it's a little less visual. open a generic data bus net, and right click then create > pin pair to make the required pin pairs. Next fill in the constraints and scopes in the relative propagation box. Finally you create an ECSet from the gerneic net and apply as before.
    Can I point you at:
    http://www.cdnusers.org/community/allegro/Resources/kits_designin/memory/stp_cdnliveemea07_ddrconstraints_veal.pdf
    It's a presentation I wrote for CdnLive last year on DDR constraints, it might be useful to you.
    Hope that helps.
    Originally posted in cdnusers.org by vealmic@uk.ibm.com
    Just newby here.. Great Explanation. I Just had some few questions, bout your pdf, not all DDR wiring is the same as the specs as explained.. correct me if i'm wrong. For example, Some ddr wiring doesn't have any pair DQS wiring as mentioned in your document. In this case, should i wire the DQS together with the byte lane? example: DQ<7...0>and DQS1, DQ<15..0>andDQS2..etc.
    Every Design has a different specification.. Most of the design i made, mostly customers wants ALL data and Addresses of the same length together. How could it be? Anyway I'm just two years in PCB design profession that's why need some clarities especially when it comes to sensitive part of design such as DDR and CPUs. Thanks.
    Originally posted in cdnusers.org by eliver
    DQS actually starts life as a single ended signal. During bringup of the DDR interface the controller turns on differential DQS in the DRAM.
    DQS needs to be the target of thematched group for each data byte, regardless of whether it's a single ended or differential signal.
    It is not necessary to route the ADDR bus the same length to every chip. Doing so will quickly get your design all tangled up. Check the DRAM spec for clock to Address tolerance and then clock to data. You should find clock to addr is reasonably tight, but clock to data (strobe) is loose.
    So, make sure clock and ADDR arrive simultaneously at each DRAM. Don't worry about any skew between DRAM devices. Each DRAM has no knowledge of the 8 other DRAMS in the rank, so why does the address have to arrive at all drams simultaneously?
    Make sure each data byte is closely matched to it's strobe.
    Finally, make sure that the strobes are loosely aligned to the clock.
    If your customer is asking you to match Address to data, address (DRAM1) to address (DRAM 2) then I'm not sure they understand DDR.
    Dear Vealmic,
    in your presentation you remark not to talk about detailed timing equations etc. We want to route a 12bit 500Mbit DDR2 bus with DStrobe and want to calculate what tolerances we can allow for the data and bus lenght matching. Can you give us a hint how or where I can find information about to calculate the timings, to set the correct propagation delay values?
    Thanks a lot!
    Originally posted in cdnusers.org by florian.herrmann@cern.ch
