  3. Padstack Editor 17.4 problem : Value must be greater than...
  • Replies 16
  • Subscribers 161
  • Views 17247
Padstack Editor 17.4 problem : Value must be greater than 0 [SOLVED]
alaphilippe
alaphilippe over 4 years ago
Hello !
I have a big problem when creating a padstack using the Padstack Editor 17.4
In the "drill" tab, I cannot enter any numeric data without having the error message: "Value must be greater than 0"
This problem does not appear in version 17.2  padstack editor
For  SMD pad, I have the same problem in configuring the dimensions.
My Cadence version is up to date
Anyone have a solution?
  • Tyler
    Tyler over 4 years ago
    Try using a period for the decimal separator instead of the comma. It might be that the tool is assuming one set of separators only for input, even though it looks like it is displaying the correct formatting on the screen per your settings.
  • alaphilippe
    alaphilippe over 4 years ago in reply to Tyler
    Thank you for the answer.
    But I tried all types of separators: point, comma, by copying / pasting, by changing the keyboard language ...
    But nothing works.
    Even a digit without decimal does not work ...
  • excellon1
    excellon1 over 4 years ago in reply to alaphilippe
    This looks like a field is missing data and that's why you are getting an error. Maybe try load an existing padstack and then save it out as a different name to see if that works first.
    What service pack version of 17.4 are you using
  • alaphilippe
    alaphilippe over 4 years ago in reply to excellon1
    I try load an existing padstack and then save it, but same error
    The version is 17.4-2019 S018 (3945310) [5/16/2021] WIndows SPB 64-bit Edition
  • excellon1
    This may be related to an issue associated with the OS.
    Try opening the pad editor only but right click on it and run the pad editor as an administrator.
    See if that works.
