  3. PCB Outline
  • State Verified Answer
  • Subscribers 160
  • Views 8438
PCB Outline
ivy372
ivy372 over 2 years ago
Hi guys,
I have write a skill that change origin to low-left of the PCB  board.
But how can I change the origin to the Board outline center point?
axlCmdRegister( "o_ll" 'o_ll ?cmdType "interactive")
(procedure o_ll()
axlExtentDB()
x = -( caar( axlExtentDB()))
y = -( cadar( axlExtentDB()))
axlDBChangeDesignOrigin( x:y )
axlUIConfirm( "Change Origin to LowLeft.")
Thanks~
  • eDave
    0 eDave over 2 years ago
    Try something like this:
    outlineShp = car(axlDBGetShapes("BOARD GEOMETRY/DESIGN_OUTLINE")) || car(axlDBGetShapes("BOARD GEOMETRY/OUTLINE"))
    if(outlineShp then
    centrePt = axlMidPointLine(outlineShp ->bBox)
    else
    axlClearSelSet()
    axlSetFindFilter(?enabled '("noall", "invisible", "lines"), ?onButtons '("noall", "lines"))
    axlAddSelectAll()
    outlines = setof(obj, axlGetSelSet(), obj ->layer == "BOARD GEOMETRY/OUTLINE")
    xMin = min(caar(car(outlines) ->bBox), caadr(car(outlines) ->bBox))
    yMin = min(cadar(car(outlines) ->bBox), cadadr(car(outlines) ->bBox))
    xMax = max(caar(car(outlines) ->bBox), caadr(car(outlines) ->bBox))
    yMax = max(cadar(car(outlines) ->bBox), cadadr(car(outlines) ->bBox))
    foreach(line, cdr(outlines)
    xMin = min(caar(line ->bBox), caadr(line ->bBox), xMin)
    yMin = min(cadar(line ->bBox), cadadr(line ->bBox), yMin)
    xMax = max(caar(line ->bBox), caadr(line ->bBox), xMax)
    yMax = max(cadar(line ->bBox), cadadr(line ->bBox), yMax)
    centrePt = axlMidPointLine(list(list(xMin, yMin), list(xMax, yMax)))
    axlDBChangeDesignOrigin(axlMXYSub(0:0, centrePt))
  • ivy372
    0 ivy372 over 2 years ago in reply to eDave
    Hi eDave,
    Thanks very much~
    But I want to change the origin to the low-left of PCB Board.
    I hope the origin set on the middle line of BOARD GEOMETRY/OUTLINE.
    like below:
  • eDave
    0 eDave over 2 years ago in reply to ivy372
    axlClearSelSet()
    axlSetFindFilter(?enabled '("noall", "invisible", "linesegs"), ?onButtons '("noall", "linesegs"))
    axlAddSelectAll()
    outlineSegments = setof(obj, axlGetSelSet(), obj ->layer == "BOARD GEOMETRY/OUTLINE")
    axlClearSelSet()
    minx = min(apply('min, mapcar('caar, outlineSegments ~>startEnd)), apply('min, mapcar('caadr, outlineSegments ~>startEnd)))
    miny = min(apply('min, mapcar('cadar, outlineSegments ~>startEnd)), apply('min, mapcar('cadadr, outlineSegments ~>startEnd)))
    axlDBChangeDesignOrigin(axlMXYSub(0:0, minx:miny))
  • ivy372
    Hi eDave,
    Awesome!
    Thanks very much~
  • JITHINDEV
    0 JITHINDEV over 2 years ago in reply to eDave
    Hi eDave,
    Can you please explain me how to execute this code.
    Jithindev
