  3. Things You Always wanted to hear on PCB Design topics: Help...
  • Replies 14
  • Subscribers 168
  • Views 15823
Things You Always wanted to hear on PCB Design topics: Help Us to Help You!
PCBTech
PCBTech over 3 years ago
We are a team at Cadence working on creating the trending topics in PCB Design.
We would like you to take a minute to vote and help us improve our content delivery in the future.
You’re welcome to add your comments if any.
Regards
Team PCBTech
Cadence Design Systems
  • Kenneth Wood
    Kenneth Wood over 3 years ago +4
    Here is what I would like you to focus on as well… Dynamically updated drill chart, current system is outdated. Dynamically updated layer stack chart. Padstack editor needs mask and paste oversize…
  • excellon1
    excellon1 over 3 years ago +2
    HI PCBTech Under your topic of "Routing Typologies" perhaps something that might be useful to Cadence Users using the PCB editor to design RF Based circuits would be an app note or best practice method…
  • PCBTech
    PCBTech over 3 years ago in reply to Kenneth Wood +1
    Thank you Ken for sharing your feedback. We are working on the Enhancements you have suggested. As we need more clarification on some of the points, we will be contacting you through different channel…
  • Kenneth Wood
    • Dynamically updated drill chart, current system is outdated.
    • Dynamically updated layer stack chart.
    • Padstack editor needs mask and paste oversize / undersize setting option rather than entering the data manually. This would save so much time for me, especially since Cadence moved them to a different tab than the copper.
    • HUGE…please please please add some wizards to the constraint manager. I love it but every time I start a new design, I have to open a previous design to remember how I set up the diff pairs, group length matching…etc…
    • As far as the poll topics:
      1. CAD Translators and Interfaces: The PADS xlator could be a lot better. PADS is dead,  we see a lot of old PADS files that need to be brought into Cadence Allegro.
      2. Routing Topologies: Best of any PCB Tool…but the arc routing could be a little less buggy.
      3. Copper fills (Shapes and Planes): Best of any PCB Tool…would be very helpful if the copper pour respected the design outline and backed off from it per the constraints.
      4. Rigid - Flex Designs: Better visuals in the cross-section manager would be helpful.
    • Vote Up +4 Vote Down
  • excellon1
    HI PCBTech
    or best practice method on how to use Cadence Allegro to implement a "Coplanar waveguide" of a specific impedance on a pcb, typically 50 ohms.
    Something like this might be handy for new or seasoned users that are designing next generation wireless based products with Orcad/Allegro.
    Best Regards,
    • Vote Up +2 Vote Down
  • Peter B
    Peter B over 3 years ago
    When comes to CAD Translators and Interfaces, please take into consideration translating KiCAD projects to OrCAD.
  • avant
    avant over 3 years ago
    For routing topologies, we use the PCB Designer (Professional) middle-tier license.
    I can set net schedules, pin pairs, min-max and relative delays. This is enough to define multi-chip Flash memory buss constraints.
    It's time consuming using the middle-tier license. I pretty much figured it out on my own, but I wonder if there are shortcuts or better methods than I am using.
  • PCBTech
    As we need more clarification on some of the points, we will be contacting you through different channel to discuss these points further in detail.
