  2. PSpice
  3. how to make Pspice model with the txt file.
  • Subscribers 33
  • Views 18137
Bilalahm
Bilalahm over 12 years ago
Hi, i need to make a Pspice part for simulation. the Maker company only gives this data.  its IRFL9014 Mosfet p channel from vishay.com
*Jun 01, 2010 *Doc. ID: 90412, Rev. A *File Name: part irfl9014_PS.txt and part irfl9014_PS.spi *This document is intended as a SPICE modeling guideline and does not *constitute a commercial product data sheet. Designers should refer to the *appropriate data sheet of the same number for guaranteed specification *limits. .SUBCKT irfl9014 1 2 3 ************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * *Commercial Use or Resale Restricted * * by Symmetry License Agreement * ************************************** * Model generated on Oct 22, 96 * MODEL FORMAT: SPICE3 * Symmetry POWER MOS Model (Version 1.0) * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=100u W=100u * Default values used in MM: * The voltage-dependent capacitances are * not included. Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM PMOS LEVEL=1 IS=1e-32 +VTO=-3.87971 LAMBDA=0.0503704 KP=0.713612 +CGSO=2.47152e-06 CGDO=1e-11 RS 8 3 0.116837 D1 1 3 MD .MODEL MD D IS=5e-21 RS=0.15039 N=1.5 BV=60 +IBV=10 EG=1.2 XTI=4 TT=1e-07 +CJO=4.40194e-10 VJ=1.63887 M=0.440757 FC=0.5 RDS 3 1 600000 RD 9 1 0.0001 RG 2 7 9.4415 D2 5 4 MD1 * Default values used in MD1: * RS=0 EG=1.11 XTI=3.0 TT=0 * BV=infinite IBV=1mA .MODEL MD1 D IS=1e-32 N=50 +CJO=1.96085e-10 VJ=0.665506 M=0.480463 FC=1e-08 D3 5 0 MD2 * Default values used in MD2: * EG=1.11 XTI=3.0 TT=0 CJO=0 * BV=infinite IBV=1mA .MODEL MD2 D IS=1e-10 N=0.4 RS=3.00002e-06 RL 5 10 1 FI2 7 9 VFI2 -1 VFI2 4 0 0 EV16 10 0 9 7 1 CAP 11 10 6.62636e-10 FI1 7 9 VFI1 -1 VFI1 11 6 0 RCAP 6 10 1 D4 6 0 MD3 * Default values used in MD3: * EG=1.11 XTI=3.0 TT=0 CJO=0 * RS=0 BV=infinite IBV=1mA .MODEL MD3 D IS=1e-10 N=0.4 .ENDS irfl9014
I made a model by model editor.
getting errors. like
INFO(ORPSIM-15423): Unable to find index file irfl9014.ind for library file irfl9014.lib.
INFO(ORPSIM-15422): Making new index file irfl9014.ind for library file irfl9014.lib.
Index has 0 entries from 1 file(s).
ERROR(ORPSIM-15108): Subcircuit IRFL9014 used by X_M1 is undefined
  • oldmouldy
    0 oldmouldy over 12 years ago
    From the supplied data it looks like the formatting of the file has been removed. Line formatting is critical to the functioning of the SPICE text models since the "columns", character positions, have fixed functions. For example, .SUBCKT denotes the start of the sub-circuit definition and the "." must be the first character on the line.
  • davismeissner
    0 davismeissner over 6 years ago
    I also want to know how to do this. I am trying to implement these parts I found online but I can't find an up to date tutorial to show me how to do this in orcad v 17.2
    * Duncan Amplfication Generic Triode Model (PSpice Implementation)
    * Copyright (C)1997-2004 Duncan Amplfication
    * Unauthorised Commercial use prohibited
    * Please refer to documentation at http://www.duncanamps.com
    * $MODEL_VERSION$ 4.1
    * $AUTOGENERATED$ 23/01/2004 20:24:26
    * CURRENT MODEL SET AND VERSIONS:
    * 2A3 [3.2, 09/08/2003 ]
    * 3CX300 [3.1, 05/01/1998 ]
    * SV6AS7 [3.0, 30/12/1997 ]
    * 6BM8 / ECL82 [3.0, 31/12/1997 ]
    * 6DJ8 / ECC88 [3.0, 15/08/1998 ]
    * 6N1P [3.0, 25/01/1998 ]
    * 6SN7GTB [3.1, 05/01/1998 ]
    * 12AT7 / ECC81 [3.1, 05/01/1998 ]
    * 12AU7 / ECC82 [3.2, 01/05/2002 ]
    * 12AX7 / ECC83 [3.0, 30/12/1997 ]
    * 76 [3.0, 12/02/1998 ]
    * 300B [3.1, 06/01/1998 ]
    * SV572-3 [3.0, 31/12/1997 ]
    * SV572-10 [3.0, 20/06/1998 ]
    * 5751 [3.0, 15/02/1998 ]
    * CORE MODEL VERSION HISTORY:
    * 1.0 23/09/1997 Initial model
    * 1.1 19/11/1997 Model altered for 1 gig resistors between each node and ground
    * 2.0 18/12/1997 Two new parameters, ERP and ERI added
    * 3.0 30/12/1997 New parameter added, RAS
    * 3.1 05/01/1998 ERI parameter removed
    * 3.2 06/01/1998 Fix errors in Pspice model
    * 3.3 13/01/1998 Fixed errors with CDO parameter
    * 3.4 25/01/1998 Errors with heater versions using ERI fixed
    * 4.1 23/01/2004 Corrections to Pspice syntax for LTSpice
    .SUBCKT TRIODE A G K H1 H2
    +PARAMS: RCO=1.6 RHO=10.5 HTV=6.3 HWU=10.5
    + LIP=1 LIF=3.7E-3 RAF=18E-3 RAS=1 CDO=0 RAP=4E-3
    + ERP=1.5
    + MU0=17.3 MUR=19E-3 EMC=9.6E-6 GCO=0 GCF=213E-6
    + CGA=3.9p CGK=2.4p CAK=0.7p
    * Heater model
    * Can be operated from AC or DC power sources.
    * NB: When operating from DC power sources, "Skip initial transient
    * solution" must be checked, to make use of this model.
    * PARAMETERS
    * RCO Heater resistance cold (ohms)
    * RHO Heater resistance hot (ohms)
    * HTV Normal heater voltage (V)
    * HWU Heater time to warm up to 90% of emission (seconds)
    Rcool H1 HA {RCO}
    Rload HA HB 1M
    Esens HD 0 VALUE {V(HA,HB)*1000}
    Epwr HE 0 VALUE {V(H1,H2)*V(HD)/(PWR({HTV},2)/{RHO})}
    RH1 HE HF 91k
    CH1 HF 0 {HWU/1E6}
    EH2 HG 0 VALUE {V(HF)}
    RH2 HG HH 270k
    CH2 HH 0 {HWU/1E6}
    EH3 HJ 0 VALUE {LIMIT(V(HH)-0.75,0,1E6)*4}
    RH3 HJ HK 91k
    CH3 HK 0 {HWU/1E6}
    Ghot HB H2 VALUE {(1/(V(HG)+0.001))/({RHO}-{RCO})*V(HB,H2)}
    * Anode/grid model
    * Models reduction in mu at large negative grid voltages
    * Models change in Ra with negative grid voltages
    * Models limit in Ia with high +Vg and low Va
    * PARAMETERS
    * LIP Conduction limit exponent
    * LIF Conduction limit factor
    * CDO Conduction offset
    * RAF Anode resistance factor for neg grid voltages
    * RAP Anode resistance factor for positive grid voltages
    * ERP Emission power
    * MU0 Mu between grid and anode at Vg=0
    * MUR Mu reduction factor for large negative grid voltages
    * EMC Emission coefficient
    * GCO Grid current offset in volts
    * GCF Grid current scale factor
    Elim LI 0 VALUE {PWR(LIMIT(V(A,K),0,1E6),{LIP})*{LIF}}
    Egg GG 0 VALUE {V(G,K)-{CDO}}
    Erpf RP 0 VALUE {1-PWR(LIMIT(-V(GG)*{RAF},0,0.999),{RAS})+LIMIT(V(GG),0,1E6)*{RAP}}
    Egr GR 0 VALUE {LIMIT(V(GG),0,1E6)+LIMIT((V(GG))*(1+V(GG)*{MUR}),0,-1E6)}
    Eem EM 0 VALUE {LIMIT(V(A,K)+V(GR)*{MU0},0,1E6)}
    Eep EP 0 VALUE {PWR(V(EM),ERP)*{EMC}*V(RP)}
    Eel EL 0 VALUE {LIMIT(V(EP),0,V(LI))}
    Eld LD 0 VALUE {LIMIT(V(EP)-V(LI),0,1E6)}
    Ga A K VALUE {V(HK)*V(EL)}
    * Grid current model
    * Models grid current, along with rise in grid current at low Va
    Egf GF 0 VALUE {PWR(LIMIT(V(G,K)-{GCO},0,1E6),1.5)*{GCF}}
    Gg G K VALUE {(V(GF)+V(LD))*V(HK)}
    * Capacitances and anti-float resistors
    CM1 G K {CGK}
    CM2 A G {CGA}
    CM3 A K {CAK}
    RF1 A 0 1000MEG
    RF2 G 0 1000MEG
    RF3 K 0 1000MEG
    .ENDS
    .SUBCKT TRIODENH A G K
    +PARAMS: LIP=1 LIF=3.7E-3 RAF=18E-3 RAS=1 CDO=0 RAP=4E-3
    + ERP=1.5
    * Anode/grid model
    * PARAMETERS
    Ga A K VALUE {V(EL)}
    Gg G K VALUE {(V(GF)+V(LD))}
    CM1 G K {CGK}
    CM2 A G {CGA}
    CM3 A K {CAK}
    RF1 A 0 1000MEG
    RF2 G 0 1000MEG
    RF3 K 0 1000MEG
    .ENDS
    * GENERIC: 2A3
    * MODEL: NH2A3
    * NOTES: No heater model (virtual cathode)
    .SUBCKT NH2A3 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 0.003 RAF= 1.92357959289845E-02 RAS= 5.31355720568454E-02 CDO= 0
    + RAP= 0.005 ERP= 1.55
    + MU0= 4.2 MUR= 0.001023047 EMC= 0.0000868
    + GCO=-0.2 GCF= 0.00001
    + CGA=1.65E-11 CGK=7.50E-12 CAK=5.50E-12
    .ENDS
    * GENERIC: 3CX300
    * MODEL: NH3CX300
    .SUBCKT NH3CX300 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.00536 RAS= 1 CDO= 0
    + RAP= 0.005 ERP= 1.25
    + MU0= 8.321 MUR= 0.0012 EMC= 0.000533
    + GCO= 0 GCF= 0.0001
    + CGA=1.00E-11 CGK=2.50E-11 CAK=1.00E-12
    .ENDS
    * GENERIC: SV6AS7
    * MODEL: NHSV6AS7
    .SUBCKT NHSV6AS7 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 0.01 RAF= 0.0058 RAS= 0.7 CDO= 0
    + RAP= 0.035 ERP= 1.5
    + MU0= 2.05 MUR= 0.0017 EMC= 0.0005
    + GCO= 0 GCF= 0
    + CGA=1.10E-11 CGK=8.00E-12 CAK=3.00E-12
    .ENDS
    * GENERIC: 6BM8 / ECL82
    * MODEL: NH6BM8
    * NOTES: No heater or grid model
    .SUBCKT NH6BM8 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.030667 RAS= 5 CDO=-0.5
    + RAP= 0.587 ERP= 1.5
    + MU0= 50 MUR= 0.035 EMC= 0.00000256
    + GCO= 0 GCF= 0
    + CGA=4.00E-12 CGK=2.70E-12 CAK=4.00E-12
    .ENDS
    * GENERIC: 6DJ8 / ECC88
    * MODEL: NH6DJ8
    * NOTES: No heater or grid current model
    .SUBCKT NH6DJ8 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.09 RAS= 0.2 CDO= 0
    + RAP= 0 ERP= 1.35
    + MU0= 33 MUR= 0.02 EMC= 0.0000795
    + GCO=-0.2 GCF= 0
    + CGA=1.40E-12 CGK=3.30E-12 CAK=1.80E-12
    .ENDS
    * GENERIC: 6N1P
    * MODEL: NH6N1P
    * NOTES: No heater/grid model
    .SUBCKT NH6N1P A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.01 RAS= 1 CDO= 0
    + RAP= 0 ERP= 1.6
    + MU0= 37.5 MUR= 0.01 EMC= 0.000005
    + GCO= 0 GCF= 0
    + CGA=1.60E-12 CGK=3.20E-12 CAK=1.50E-12
    .ENDS
    * GENERIC: 6SN7GTB
    * MODEL: 6SN7GTB
    * NOTES: Has heater model (one half of heater)
    .SUBCKT 6SN7GTB A G K H1 H2
    XV1 A G K H1 H2 TRIODE
    +PARAMS: RCO= 3.2 RHO= 21 HTV= 6.3 HWU= 10.5
    + LIP= 1 LIF= 0.0037 RAF= 0.02 RAS= 2 CDO= 0
    + RAP= 0.002 ERP= 1.4
    + MU0= 19.2642 MUR= 0.006167 EMC= 0.0000189
    + GCO= 0 GCF= 0.000213
    + CGA=3.90E-12 CGK=2.40E-12 CAK=7.00E-13
    .ENDS
    * GENERIC: 6SN7GTB
    * MODEL: NH6SN7GTB
    .SUBCKT NH6SN7GTB A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.02 RAS= 2 CDO= 0
    .ENDS
    * GENERIC: 12AT7 / ECC81
    * MODEL: 12AT7
    * NOTES: Heater model for one half of heater (6.3V)
    .SUBCKT 12AT7 A G K H1 H2
    +PARAMS: RCO= 6.2 RHO= 42 HTV= 6.3 HWU= 10.5
    + LIP= 1 LIF= 0.0037 RAF= 0.09869 RAS= 1 CDO=-0.5
    + RAP= 0.1 ERP= 1.4
    + MU0= 45.093 MUR= 0.012937 EMC= 0.00000863
    + GCO=-0.5 GCF= 0.00012
    + CGA=1.60E-12 CGK=2.30E-12 CAK=4.00E-13
    .ENDS
    * MODEL: NH12AT7
    .SUBCKT NH12AT7 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.09869 RAS= 1 CDO=-0.5
    + RAP= 0.1 ERP= 1.4
    .ENDS
    * GENERIC: 12AU7 / ECC82
    * MODEL: 12AU7
    .SUBCKT 12AU7 A G K H1 H2
    + LIP= 1 LIF= 0.0037 RAF= 0.024778659 RAS= 2.040491735 CDO= 0
    + RAP= 0.18 ERP= 1.35
    + MU0= 14.27427 MUR= 0.005857103 EMC= 0.0000236
    + GCO= 0 GCF= 0.00012
    + CGA=1.60E-12 CGK=1.80E-12 CAK=4.50E-13
    .ENDS
    * MODEL: NH12AU7
    .SUBCKT NH12AU7 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.000001 RAS= 2.065382774 CDO= 0
    + RAP= 0.18 ERP= 1.4
    + MU0= 17.08958652 MUR= 0.010938375 EMC= 0.0000183
    .ENDS
    * GENERIC: 12AX7 / ECC83
    * MODEL: 12AX7
    .SUBCKT 12AX7 A G K H1 H2
    + LIP= 1.5 LIF= 0.000016 RAF= 0.076498 RAS= 1 CDO=-0.53056
    + RAP= 0.18 ERP= 1.5
    + MU0= 87.302 MUR=-0.013621 EMC= 0.00000111
    .ENDS
    * MODEL: NH12AX7
    .SUBCKT NH12AX7 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 0.000016 RAF= 0.076498 RAS= 1 CDO=-0.53056
    .ENDS
    * GENERIC: 76
    * MODEL: NH76
    .SUBCKT NH76 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 10 RAF= 0.015 RAS= 1.8 CDO= 0
    + RAP= 0 ERP= 1.6
    + MU0= 12.8 MUR= 0.001 EMC= 0.000008
    + GCO= 0 GCF= 0
    + CGA=2.80E-12 CGK=3.50E-12 CAK=2.50E-12
    .ENDS
    * GENERIC: 300B
    * MODEL: NH300B
    * NOTES: No heater/grid model (virtual cathode)
    .SUBCKT NH300B A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 10 RAF= 0.00311 RAS= 1.013608 CDO= 0
    + RAP= 0 ERP= 1.5
    + MU0= 3.7992 MUR= 0.000362 EMC= 0.000116
    + GCO= 0 GCF= 0
    + CGA=1.50E-11 CGK=9.00E-12 CAK=4.30E-12
    .ENDS
    * GENERIC: SV572-3
    * MODEL: SV5723
    .SUBCKT SV5723 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1 LIF= 0.0018 RAF= 0.0012 RAS= 0.5 CDO= 0
    + RAP= 0 ERP= 1.4
    + MU0= 3.79928 MUR= 0.0002 EMC= 0.0000425
    + GCO= 0 GCF= 0.0000349
    + CGA=4.00E-12 CGK=4.00E-12 CAK=1.00E-12
    .ENDS
    * GENERIC: SV572-10
    * MODEL: SV57210
    * NOTES: This model is not accurate for Vg >= +60V
    .SUBCKT SV57210 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.4 LIF= 0.0008 RAF= 0.001 RAS= 1 CDO= 0
    + RAP=-0.00117 ERP= 1.38
    + MU0= 10 MUR= 0.0001 EMC= 0.0000272
    + GCO=-0.2 GCF= 0.0003
    + CGA=5.00E-12 CGK=6.40E-12 CAK=1.00E-12
    .ENDS
    * GENERIC: 5751
    * MODEL: NH5751
    .SUBCKT NH5751 A G K
    XV1 A G K TRIODENH
    +PARAMS: LIP= 1.5 LIF= 0.000016 RAF= 0.075772 RAS= 1 CDO=-0.53056
    + RAP= 0.131285 ERP= 1.5
    + MU0= 62.94685 MUR=-0.0111 EMC= 0.00000142
    + CGA=1.40E-12 CGK=1.40E-12 CAK=4.50E-13
    .ENDS
  • davismeissner
    ********************************************************************** * Duncan Amplfication Generic Triode Model (PSpice Implementation) * Copyright (C)1997-2004 Duncan Amplfication * Unauthorised Commercial use prohibited * Please refer to documentation at  * * $MODEL_VERSION$ 4.1 * $AUTOGENERATED$ 23/01/2004 20:24:26  ********************************************************************** * CURRENT MODEL SET AND VERSIONS: * * 2A3 [3.2, 09/08/2003 ] * 3CX300 [3.1, 05/01/1998 ] * SV6AS7 [3.0, 30/12/1997 ] * 6BM8 / ECL82 [3.0, 31/12/1997 ] * 6DJ8 / ECC88 [3.0, 15/08/1998 ] * 6N1P [3.0, 25/01/1998 ] * 6SN7GTB [3.1, 05/01/1998 ] * 12AT7 / ECC81 [3.1, 05/01/1998 ] * 12AU7 / ECC82 [3.2, 01/05/2002 ] * 12AX7 / ECC83 [3.0, 30/12/1997 ] * 76 [3.0, 12/02/1998 ] * 300B [3.1, 06/01/1998 ] * SV572-3 [3.0, 31/12/1997 ] * SV572-10 [3.0, 20/06/1998 ] * 5751 [3.0, 15/02/1998 ] ********************************************************************** * CORE MODEL VERSION HISTORY: * * 1.0 23/09/1997 Initial model * 1.1 19/11/1997 Model altered for 1 gig resistors between each node and ground * 2.0 18/12/1997 Two new parameters, ERP and ERI added * 3.0 30/12/1997 New parameter added, RAS * 3.1 05/01/1998 ERI parameter removed * 3.2 06/01/1998 Fix errors in Pspice model * 3.3 13/01/1998 Fixed errors with CDO parameter * 3.4 25/01/1998 Errors with heater versions using ERI fixed * 4.1 23/01/2004 Corrections to Pspice syntax for LTSpice ********************************************************************** .SUBCKT TRIODE A G K H1 H2 +PARAMS: RCO=1.6 RHO=10.5 HTV=6.3 HWU=10.5 + LIP=1 LIF=3.7E-3 RAF=18E-3 RAS=1 CDO=0 RAP=4E-3 + ERP=1.5  + MU0=17.3 MUR=19E-3 EMC=9.6E-6 GCO=0 GCF=213E-6 + CGA=3.9p CGK=2.4p CAK=0.7p
    ************************************************************************ * * Heater model * * Can be operated from AC or DC power sources. * NB: When operating from DC power sources, "Skip initial transient * solution" must be checked, to make use of this model. * * PARAMETERS * * RCO Heater resistance cold (ohms) * RHO Heater resistance hot (ohms) * HTV Normal heater voltage (V) * HWU Heater time to warm up to 90% of emission (seconds) * ************************************************************************
    Rcool H1 HA {RCO} Rload HA HB 1M Esens HD 0 VALUE {V(HA,HB)*1000} Epwr HE 0 VALUE {V(H1,H2)*V(HD)/(PWR({HTV},2)/{RHO})} RH1 HE HF 91k CH1 HF 0 {HWU/1E6} EH2 HG 0 VALUE {V(HF)} RH2 HG HH 270k CH2 HH 0 {HWU/1E6} EH3 HJ 0 VALUE {LIMIT(V(HH)-0.75,0,1E6)*4} RH3 HJ HK 91k CH3 HK 0 {HWU/1E6} Ghot HB H2 VALUE {(1/(V(HG)+0.001))/({RHO}-{RCO})*V(HB,H2)}
    ************************************************************************ * * Anode/grid model * * Models reduction in mu at large negative grid voltages * Models change in Ra with negative grid voltages * Models limit in Ia with high +Vg and low Va * * PARAMETERS * * LIP Conduction limit exponent * LIF Conduction limit factor * CDO Conduction offset * RAF Anode resistance factor for neg grid voltages * RAP Anode resistance factor for positive grid voltages * ERP Emission power * MU0 Mu between grid and anode at Vg=0 * MUR Mu reduction factor for large negative grid voltages * EMC Emission coefficient * GCO Grid current offset in volts * GCF Grid current scale factor * ************************************************************************
    Elim LI 0 VALUE {PWR(LIMIT(V(A,K),0,1E6),{LIP})*{LIF}} Egg GG 0 VALUE {V(G,K)-{CDO}} Erpf RP 0 VALUE {1-PWR(LIMIT(-V(GG)*{RAF},0,0.999),{RAS})+LIMIT(V(GG),0,1E6)*{RAP}} Egr GR 0 VALUE {LIMIT(V(GG),0,1E6)+LIMIT((V(GG))*(1+V(GG)*{MUR}),0,-1E6)} Eem EM 0 VALUE {LIMIT(V(A,K)+V(GR)*{MU0},0,1E6)} Eep EP 0 VALUE {PWR(V(EM),ERP)*{EMC}*V(RP)} Eel EL 0 VALUE {LIMIT(V(EP),0,V(LI))} Eld LD 0 VALUE {LIMIT(V(EP)-V(LI),0,1E6)} Ga A K VALUE {V(HK)*V(EL)}
    ************************************************************************ * * Grid current model * * Models grid current, along with rise in grid current at low Va * ************************************************************************ Egf GF 0 VALUE {PWR(LIMIT(V(G,K)-{GCO},0,1E6),1.5)*{GCF}} Gg G K VALUE {(V(GF)+V(LD))*V(HK)}
    * * Capacitances and anti-float resistors * CM1 G K {CGK} CM2 A G {CGA} CM3 A K {CAK} RF1 A 0 1000MEG RF2 G 0 1000MEG RF3 K 0 1000MEG
    .ENDS
    .SUBCKT TRIODENH A G K +PARAMS: LIP=1 LIF=3.7E-3 RAF=18E-3 RAS=1 CDO=0 RAP=4E-3 + ERP=1.5 + MU0=17.3 MUR=19E-3 EMC=9.6E-6 GCO=0 GCF=213E-6 + CGA=3.9p CGK=2.4p CAK=0.7p
    Elim LI 0 VALUE {PWR(LIMIT(V(A,K),0,1E6),{LIP})*{LIF}} Egg GG 0 VALUE {V(G,K)-{CDO}} Erpf RP 0 VALUE {1-PWR(LIMIT(-V(GG)*{RAF},0,0.999),{RAS})+LIMIT(V(GG),0,1E6)*{RAP}} Egr GR 0 VALUE {LIMIT(V(GG),0,1E6)+LIMIT((V(GG))*(1+V(GG)*{MUR}),0,-1E6)} Eem EM 0 VALUE {LIMIT(V(A,K)+V(GR)*{MU0},0,1E6)} Eep EP 0 VALUE {PWR(V(EM),ERP)*{EMC}*V(RP)} Eel EL 0 VALUE {LIMIT(V(EP),0,V(LI))} Eld LD 0 VALUE {LIMIT(V(EP)-V(LI),0,1E6)} Ga A K VALUE {V(EL)}
    ************************************************************************ * * Grid current model * * Models grid current, along with rise in grid current at low Va * ************************************************************************ Egf GF 0 VALUE {PWR(LIMIT(V(G,K)-{GCO},0,1E6),1.5)*{GCF}} Gg G K VALUE {(V(GF)+V(LD))}
    .ENDS ********************************************************************** * GENERIC: 2A3 * MODEL: NH2A3 * NOTES: No heater model (virtual cathode) ********************************************************************** .SUBCKT NH2A3 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 0.003 RAF= 1.92357959289845E-02 RAS= 5.31355720568454E-02 CDO= 0  + RAP= 0.005 ERP= 1.55  + MU0= 4.2 MUR= 0.001023047 EMC= 0.0000868  + GCO=-0.2 GCF= 0.00001  + CGA=1.65E-11 CGK=7.50E-12 CAK=5.50E-12 .ENDS
    ********************************************************************** * GENERIC: 3CX300 * MODEL: NH3CX300 * NOTES: No heater model ********************************************************************** .SUBCKT NH3CX300 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.00536 RAS= 1 CDO= 0  + RAP= 0.005 ERP= 1.25  + MU0= 8.321 MUR= 0.0012 EMC= 0.000533  + GCO= 0 GCF= 0.0001  + CGA=1.00E-11 CGK=2.50E-11 CAK=1.00E-12 .ENDS
    ********************************************************************** * GENERIC: SV6AS7 * MODEL: NHSV6AS7 * NOTES: No heater model ********************************************************************** .SUBCKT NHSV6AS7 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 0.01 RAF= 0.0058 RAS= 0.7 CDO= 0  + RAP= 0.035 ERP= 1.5  + MU0= 2.05 MUR= 0.0017 EMC= 0.0005  + GCO= 0 GCF= 0  + CGA=1.10E-11 CGK=8.00E-12 CAK=3.00E-12 .ENDS
    ********************************************************************** * GENERIC: 6BM8 / ECL82 * MODEL: NH6BM8 * NOTES: No heater or grid model ********************************************************************** .SUBCKT NH6BM8 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.030667 RAS= 5 CDO=-0.5  + RAP= 0.587 ERP= 1.5  + MU0= 50 MUR= 0.035 EMC= 0.00000256  + GCO= 0 GCF= 0  + CGA=4.00E-12 CGK=2.70E-12 CAK=4.00E-12 .ENDS
    ********************************************************************** * GENERIC: 6DJ8 / ECC88 * MODEL: NH6DJ8 * NOTES: No heater or grid current model ********************************************************************** .SUBCKT NH6DJ8 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.09 RAS= 0.2 CDO= 0  + RAP= 0 ERP= 1.35  + MU0= 33 MUR= 0.02 EMC= 0.0000795  + GCO=-0.2 GCF= 0  + CGA=1.40E-12 CGK=3.30E-12 CAK=1.80E-12 .ENDS
    ********************************************************************** * GENERIC: 6N1P * MODEL: NH6N1P * NOTES: No heater/grid model ********************************************************************** .SUBCKT NH6N1P A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 10 RAF= 0.01 RAS= 1 CDO= 0  + RAP= 0 ERP= 1.6  + MU0= 37.5 MUR= 0.01 EMC= 0.000005  + GCO= 0 GCF= 0  + CGA=1.60E-12 CGK=3.20E-12 CAK=1.50E-12 .ENDS
    ********************************************************************** * GENERIC: 6SN7GTB * MODEL: 6SN7GTB * NOTES: Has heater model (one half of heater) ********************************************************************** .SUBCKT 6SN7GTB A G K H1 H2 XV1 A G K H1 H2 TRIODE +PARAMS: RCO= 3.2 RHO= 21 HTV= 6.3 HWU= 10.5  + LIP= 1 LIF= 0.0037 RAF= 0.02 RAS= 2 CDO= 0  + RAP= 0.002 ERP= 1.4  + MU0= 19.2642 MUR= 0.006167 EMC= 0.0000189  + GCO= 0 GCF= 0.000213  + CGA=3.90E-12 CGK=2.40E-12 CAK=7.00E-13 .ENDS
    ********************************************************************** * GENERIC: 6SN7GTB * MODEL: NH6SN7GTB * NOTES: No heater model ********************************************************************** .SUBCKT NH6SN7GTB A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.02 RAS= 2 CDO= 0  + RAP= 0.002 ERP= 1.4  + MU0= 19.2642 MUR= 0.006167 EMC= 0.0000189  + GCO= 0 GCF= 0.000213  + CGA=3.90E-12 CGK=2.40E-12 CAK=7.00E-13 .ENDS
    ********************************************************************** * GENERIC: 12AT7 / ECC81 * MODEL: 12AT7 * NOTES: Heater model for one half of heater (6.3V) ********************************************************************** .SUBCKT 12AT7 A G K H1 H2 XV1 A G K H1 H2 TRIODE +PARAMS: RCO= 6.2 RHO= 42 HTV= 6.3 HWU= 10.5  + LIP= 1 LIF= 0.0037 RAF= 0.09869 RAS= 1 CDO=-0.5  + RAP= 0.1 ERP= 1.4  + MU0= 45.093 MUR= 0.012937 EMC= 0.00000863  + GCO=-0.5 GCF= 0.00012  + CGA=1.60E-12 CGK=2.30E-12 CAK=4.00E-13 .ENDS
    ********************************************************************** * GENERIC: 12AT7 / ECC81 * MODEL: NH12AT7 * NOTES: No heater model ********************************************************************** .SUBCKT NH12AT7 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.09869 RAS= 1 CDO=-0.5  + RAP= 0.1 ERP= 1.4  + MU0= 45.093 MUR= 0.012937 EMC= 0.00000863  + GCO=-0.5 GCF= 0.00012  + CGA=1.60E-12 CGK=2.30E-12 CAK=4.00E-13 .ENDS
    ********************************************************************** * GENERIC: 12AU7 / ECC82 * MODEL: 12AU7 * NOTES: Heater model for one half of heater (6.3V) ********************************************************************** .SUBCKT 12AU7 A G K H1 H2 XV1 A G K H1 H2 TRIODE +PARAMS: RCO= 6.2 RHO= 42 HTV= 6.3 HWU= 10.5  + LIP= 1 LIF= 0.0037 RAF= 0.024778659 RAS= 2.040491735 CDO= 0  + RAP= 0.18 ERP= 1.35  + MU0= 14.27427 MUR= 0.005857103 EMC= 0.0000236  + GCO= 0 GCF= 0.00012  + CGA=1.60E-12 CGK=1.80E-12 CAK=4.50E-13 .ENDS
    ********************************************************************** * GENERIC: 12AU7 / ECC82 * MODEL: NH12AU7 * NOTES: No heater model ********************************************************************** .SUBCKT NH12AU7 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 0.0037 RAF= 0.000001 RAS= 2.065382774 CDO= 0  + RAP= 0.18 ERP= 1.4  + MU0= 17.08958652 MUR= 0.010938375 EMC= 0.0000183  + GCO= 0 GCF= 0.00012  + CGA=1.60E-12 CGK=1.80E-12 CAK=4.50E-13 .ENDS
    ********************************************************************** * GENERIC: 12AX7 / ECC83 * MODEL: 12AX7 * NOTES: Heater model for one half of heater (6.3V) ********************************************************************** .SUBCKT 12AX7 A G K H1 H2 XV1 A G K H1 H2 TRIODE +PARAMS: RCO= 6.2 RHO= 42 HTV= 6.3 HWU= 10.5  + LIP= 1.5 LIF= 0.000016 RAF= 0.076498 RAS= 1 CDO=-0.53056  + RAP= 0.18 ERP= 1.5  + MU0= 87.302 MUR=-0.013621 EMC= 0.00000111  + GCO=-0.2 GCF= 0.00001  + CGA=3.90E-12 CGK=2.40E-12 CAK=7.00E-13 .ENDS
    ********************************************************************** * GENERIC: 12AX7 / ECC83 * MODEL: NH12AX7 * NOTES: No heater model ********************************************************************** .SUBCKT NH12AX7 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 0.000016 RAF= 0.076498 RAS= 1 CDO=-0.53056  + RAP= 0.18 ERP= 1.5  + MU0= 87.302 MUR=-0.013621 EMC= 0.00000111  + GCO=-0.2 GCF= 0.00001  + CGA=3.90E-12 CGK=2.40E-12 CAK=7.00E-13 .ENDS
    ********************************************************************** * GENERIC: 76 * MODEL: NH76 * NOTES: No heater/grid model ********************************************************************** .SUBCKT NH76 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 10 RAF= 0.015 RAS= 1.8 CDO= 0  + RAP= 0 ERP= 1.6  + MU0= 12.8 MUR= 0.001 EMC= 0.000008  + GCO= 0 GCF= 0  + CGA=2.80E-12 CGK=3.50E-12 CAK=2.50E-12 .ENDS
    ********************************************************************** * GENERIC: 300B * MODEL: NH300B * NOTES: No heater/grid model (virtual cathode) ********************************************************************** .SUBCKT NH300B A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 10 RAF= 0.00311 RAS= 1.013608 CDO= 0  + RAP= 0 ERP= 1.5  + MU0= 3.7992 MUR= 0.000362 EMC= 0.000116  + GCO= 0 GCF= 0  + CGA=1.50E-11 CGK=9.00E-12 CAK=4.30E-12 .ENDS
    ********************************************************************** * GENERIC: SV572-3 * MODEL: SV5723 * NOTES: No heater model (virtual cathode) ********************************************************************** .SUBCKT SV5723 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1 LIF= 0.0018 RAF= 0.0012 RAS= 0.5 CDO= 0  + RAP= 0 ERP= 1.4  + MU0= 3.79928 MUR= 0.0002 EMC= 0.0000425  + GCO= 0 GCF= 0.0000349  + CGA=4.00E-12 CGK=4.00E-12 CAK=1.00E-12 .ENDS
    ********************************************************************** * GENERIC: SV572-10 * MODEL: SV57210 * NOTES: This model is not accurate for Vg >= +60V ********************************************************************** .SUBCKT SV57210 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.4 LIF= 0.0008 RAF= 0.001 RAS= 1 CDO= 0  + RAP=-0.00117 ERP= 1.38  + MU0= 10 MUR= 0.0001 EMC= 0.0000272  + GCO=-0.2 GCF= 0.0003  + CGA=5.00E-12 CGK=6.40E-12 CAK=1.00E-12 .ENDS
    ********************************************************************** * GENERIC: 5751 * MODEL: NH5751 * NOTES: No heater model ********************************************************************** .SUBCKT NH5751 A G K XV1 A G K TRIODENH +PARAMS: LIP= 1.5 LIF= 0.000016 RAF= 0.075772 RAS= 1 CDO=-0.53056  + RAP= 0.131285 ERP= 1.5  + MU0= 62.94685 MUR=-0.0111 EMC= 0.00000142  + GCO=-0.2 GCF= 0.00001  + CGA=1.40E-12 CGK=1.40E-12 CAK=4.50E-13 .ENDS
    0 Andrew Beckett over 6 years ago in reply to davismeissner
    I'll leave it to somebody on these forums to respond - I'm merely commenting to the poster as a moderator (in other forums). These last two posts got flagged as potential spam because of repeated text which is often a signature of spam - which is why they got held up.
