  2. PSpice
  3. Device and System Modeling in C/C++
  • Subscribers 33
  • Views 5142
GulDuz
GulDuz over 4 years ago
I am interested in Device Model Interface (DMI), unfortunately I could only find these two documents
1-PSpice Device and System Modeling in C/C++ and SystemC Tutorial
2-PSpice Device Modeling Interface API Reference
which is very rare to understand DMI and used it with C/C++. Are there any other documents or videos?
Sincerely
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    Kindly refer this - https://www.pspice.com/resources/application-notes/device-model-interface
  • GulDuz
    0 GulDuz over 4 years ago in reply to Schulz Jordan
    Hello Jordan,
    this is almost the same as
    the analog part (Noise Filter using a MATLAB Block) is identical. There should be a user guide. How should a newbie learn it if it's not adequately documented? An example, PSpice Device Modeling Interface API Reference page 29
    typedef void(* pPSpiceIntegrate_t) (double &pConductance, double &pCurrent, double pCapacitance, qi_def&pSV0, qi_def &pSV1, qi_def &pSV2, int pInitFlag)
    how to use it if you don't know what these parameters are or how to use them. That must be documented, shouldn't it? I'm a bit disappointed in terms of documentation and help for students who aren't allowed to open a help case in Cadence.
    Sincerely
  • Klaus Kragelund
    0 Klaus Kragelund over 3 years ago in reply to GulDuz
    Hi
    I am in a similar situation. Just started on the SystemC /DMI modelling, but very little documentation on how to use the function calls in Visual Studio.
    To begin with I just need a simple analog in and analog out device, but have no luck getting it working.
  • AyushD
    0 AyushD over 3 years ago in reply to Klaus Kragelund
    Hello
    For a simple working example you can refer to the tutorial link on Cadence Support website. Check the section "Generating and Simulating a SystemC based PSpice DMI Model" in below link
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=pspsysdsnc.xml&title=PSpice%20Device%20and%20System%20Modeling%20with%20C/C++%20and%20SystemC%20Tutorial%20--%20Introduction%20to%20PSpice%20System%20Design%20-%20Prerequisites&hash=pgfId-754701&c_version=17.4-2019&path=pspSysDsnC/pspSysDsnC17.4-2019/Introduction.html#pgfId-754701
  • Klaus Kragelund
    0 Klaus Kragelund over 3 years ago in reply to AyushD
    Thanks. That provided at least a little deeper insight.
    I also found this reference:
    SystemC WP_1 (uw.edu)
