  2. PSpice
  3. Pspice Model Editor 17.4 doesn't open, only appears the...
  • State Verified Answer
  • Subscribers 32
  • Views 3487
Pspice Model Editor 17.4 doesn't open, only appears the icon in taskbar
GustavoG14522
GustavoG14522 over 3 years ago
  • rg13
    rg13 over 3 years ago in reply to GustavoG14522 +1 verified
    Agreed with Ayush. Running it in Admin mode, it should bring up the model editor on the screen. If not, try following: hover mouse over model editor icon in task bar, small preview window will appear…
  • AyushD
    0 AyushD over 3 years ago
    Try running it in admin mode, by right click on the icon and select Run as Admin.
    Which hotfix of 17.4 are you using ?
  • GustavoG14522
    0 GustavoG14522 over 3 years ago in reply to AyushD
    It's the hotfix 17.4-2019-S031
  • rg13
    +1 rg13 over 3 years ago in reply to GustavoG14522
    hover mouse over model editor icon in task bar, small preview window will appear.
    Click RMB on that small preview window and select Restore. It should bring up the model editor window now on your screen.
    Play this video
  • GustavoG14522
    0 GustavoG14522 over 3 years ago in reply to rg13
    Hi rg13,  It helped me to solve the problem, thanks!
