  2. PSpice
  3. Why am I getting the ORCOMMN-12006 Error?
  • Replies 9
  • Subscribers 34
  • Views 10604
TillW
TillW over 2 years ago
yesterday I've installed Capture CIS through the "Your Producs" page on the cadence Homepage.
So I pressed the "download" button an went through the setup process.
I can build a simple circuit and simulate it through PSpice but i cant open any .lib files. When I try to do so, the following window pops up.
I've already tried to update my license but it didnt work.
What have I done wrong?
Greetings
Till
  • AyushD
    AyushD over 2 years ago +1
    You said that you are able to run the simulation but getting error while opening a .lib file. How are you trying to open a .lib file ? Are you trying to open the file in model editor ?
  • TdB
    TdB over 2 years ago +1
    i have the same problem did you mange to fix it after all?
  • Pretter
    0 Pretter over 2 years ago in reply to Pretter
  • Technofiction
    0 Technofiction over 2 years ago in reply to Pretter
    Check the environment variable CDS_LIC_FILE is set properly and pointing to correct active license file.
  • Pretter
    0 Pretter over 2 years ago in reply to Technofiction
    I updated to Orcad X and I think it still using my old licens. Tho with the new version I cant seem to find the licens.dat and dunno what server it should be pointing to
  • Pretter
    So my CDS_LIC_FILE points to a old licens file in SPB17_4. Where do I find the licens for orcad X?
