  2. PSpice
  3. Why am I getting the ORCOMMN-12006 Error?
  • Replies 9
  • Subscribers 34
  • Views 10603
TillW
TillW over 2 years ago
yesterday I've installed Capture CIS through the "Your Producs" page on the cadence Homepage.
So I pressed the "download" button an went through the setup process.
I can build a simple circuit and simulate it through PSpice but i cant open any .lib files. When I try to do so, the following window pops up.
I've already tried to update my license but it didnt work.
What have I done wrong?
Greetings
Till
  • AyushD
    AyushD over 2 years ago +1
    You said that you are able to run the simulation but getting error while opening a .lib file. How are you trying to open a .lib file ? Are you trying to open the file in model editor ?
  • TdB
    TdB over 2 years ago +1
    i have the same problem did you mange to fix it after all?
  • AyushD
    0 AyushD over 2 years ago
  • TdB
    0 TdB over 2 years ago
  • Pretter
    0 Pretter over 2 years ago
    Also got this problem. Did you fix it?
  • Technofiction
    0 Technofiction over 2 years ago
    Can you try the below steps and check if this help:
    1.With invoked Capture tool.
    2.Go to Options >Extended preferences>Licensing mode.
    3.Change it from use Standalone licensing(Single User License) to Connect License Server.
    4.Close all running tools and reinvoke capture. Now try to simulate through PSpice.
    Try the above and share your inputs.
  • Pretter
    0 Pretter over 2 years ago in reply to Technofiction
    Technofiction said:
    reinvoke c
    Thanks! how do i reinvoke capture? I changed the license settings but now CIS dont start.
