  2. PSpice
  3. Including parameters in measurement expression
  • State Verified Answer
  • Subscribers 31
  • Views 6234
carolinawalter
carolinawalter over 2 years ago
I have an established parameter, in this case called "CLOAD" when I use it in the schematic program and I need to call it this it can be done with the curly brackets {CLOAD}.
I have a mathematical equation that is evaluated in the post processor that helps calculate a value,
1/(10e-9*2*pi*XatNthY(DB(V(AOL_LOADED)),20,1))
This measurement works great and provides the value I want.
I would like to change the measurement to be more dynamic.
I would like to use the parameter in the measurement equation, like this:
1/({CLOAD}*2*pi*XatNthY(DB(V(AOL_LOADED)),20,1))
This provides an error, is it possible to call into measurement expressions a parameter value?
Note: I am using an AC analysis without parametric stepping. Therefore i=Cdv/dt cannot be used since there is no time component.
All the best,
Carolina
  • TechiEE12
    TechiEE12 over 2 years ago in reply to TechiEE12 +1 verified
    You can try something like this : In your case RLOAD is CLOAD. Using @PSpice and .probe statement will get RLOAD into netlist and you will be able to add this in probe window. For measurement expressions…
  • TechiEE12
    0 TechiEE12 over 2 years ago
    CLOAD is defined as parameter which would be understood by simulator and not by probe. You can try to add the statement .probe P(param_name) on capture canvas as PSpice directive, so that probe recognizes it and now try to use as P(param name) inside expression.
  • TechiEE12
    +1 TechiEE12 over 2 years ago in reply to TechiEE12
    In your case RLOAD is CLOAD. Using @PSpice and .probe statement will get RLOAD into netlist and you will be able to add this in probe window. For measurement expressions try using something like :
    1/(Min(P(RLOAD))*10e-9*2*pi*XatNthY(DB(V(OUT1)),20,1)) OR
    1/(Max(P(RLOAD))*10e-9*2*pi*XatNthY(DB(V(OUT1)),20,1))
    Hope this helps.
  • carolinawalter
    0 carolinawalter over 2 years ago in reply to TechiEE12
    This is very helpful! Thank you so much! Have a nice day Slight smile
