  2. PSpice
  3. AD8338ACPZ-R7
  • State Suggested Answer
  • Answers 1
  • Subscribers 33
  • Views 4652
AD8338ACPZ-R7
GM202407172538
GM202407172538 over 2 years ago
I download the Pspice model of AD8338ACPZ-R7 from the manufacter industry.
But i can't associate the Pspice model to the simbol.
How can i do ?
  • retiredEE
    retiredEE over 2 years ago +1 suggested
    If you downloaded the AD8338 model from ADI’s website you have a model which contains “B” type circuit elements. These elements are LTspice components and differ from the GaAsFET PSpice “B” part. This…
  • retiredEE
    0 retiredEE over 2 years ago
    If you downloaded the AD8338 model from ADI’s website you have a model which contains “B” type circuit elements.  These elements are LTspice components and differ from the GaAsFET PSpice “B” part.  This model is incompatible with PSpice.
  • GM202407172538
    0 GM202407172538 over 2 years ago in reply to retiredEE
    Dove posso trovare un modello compatibile per orCad X Professional Plus Capture?% MCEPASTEBIN%
  • HIMS
    0 HIMS over 2 years ago
    Try using this -
    * AD8338 SPICE Model
    * Description: Linear-in-dB 80dB Variable Gain Amplifier
    * Developed by: ADI
    * Revision History: 08/13/2013
    * 1.0 (08/2013)
    * Copyright 2013 by Analog Devices, Inc.
    * Refer to www.analog.com/.../spice_general.html for License Statement. Use of this model
    * indicates your acceptance with the terms and provisions in the License Statement.
    * BEGIN Notes:
    * Parameters modeled include:
    * Gain bandwidth product
    * Internal 1.5V reference
    * A Gain control pin, configured for cases where MODE=HIGH (increasing gain with increasing voltage)
    * Sensitivity to different input resistors for Gain or attenuation
    * slew rate and step response performance
    * Sensitivity to feedback resistors
    * Noise with respect to input resistors
    * Parameters not explicitly modeled:
    * Offset Nulling Circuit
    * MODE control (increasing, or decreasing gain with increasing voltage)
    * AGC/DetectorOut
    * END Notes
    * Node assignments
    * Non inverting input, with 500ohm internal resistor
    * | Non inverting input, direct
    * | | Inverting input, direct
    * | | | Inverting Input, with 500ohm internal resistor
    * | | | | Signal common/ground
    * | | | | | Gain control pin
    * | | | | | | Feedback pin (inverting output)
    * | | | | | | | Inverting output
    * | | | | | | | | Non-inverting output
    * | | | | | | | | | Feedback pin (non-inverting)
    * | | | | | | | | | | Supply pin (3-5V)
    * | | | | | | | | | | | Reference output, 1.5V
    .SUBCKT AD8338 INPR INPD INMD INMR COMM GAIN FBKM OUTM OUTP FBKP VBAT VREF
    *Reference
    V100 VREF 0 1.500
    *Input stage
    R001 INPR INPD 500
    R002 INMR INMD 500
    VSENS1 INPD VREF 0
    VSENS2 VREF INMD 0
    *Differential to single-ended
    F001 0 VSUM VSENS1 0.05
    F002 0 VSUM VSENS2 0.05
    R010 VSUM 0 10e3
    *Gain scaling
    EGAIN VGAINOUT 0 VALUE {PWR(10,4*(V(GAIN)-0.1))*V(VSUM)}
    R020 VGAINOUT 0 1e9
    *Slewing circuit
    GSLEW VSLEW 0 VALUE {(-1)*LIMIT((V(VGAINOUT)-V(VSLEW)),0.002,-0.002)}
    C010 VSLEW 0 10e-12
    *Gainbandwidth limiting
    G001 0 VPRE VSLEW 0 -0.05
    R040 VPRE 0 20
    C050 VPRE 0 442e-12
    ECLAMP VLIMIT 0 VALUE {LIMIT(V(VPRE), 1.55, -1.55)}
    *Output Transimpedance Amplifier
    G010 0 FBKP VLIMIT 0 0.052631e-3
    G011 FBKM 0 VLIMIT 0 0.052631e-3
    E100 OUTP 0 VREF FBKP 1e5
    E101 OUTM 0 VREF FBKM 1e5
    R099 OUTP FBKP 9500
    R098 OUTM FBKM 9500
    *supply current
    GMEAS VBAT 0 VALUE {(V(GAIN)-0.6)*(V(GAIN)-0.6)*0.012+0.003}
    .MODEL DGeneric D Is=1e-15
    .ends
  • HIMS
    Try this -
    * Node assignments
    *Reference
    V100 VREF 0 1.500
    *Input stage
    R001 INPR INPD 500
    R002 INMR INMD 500
    VSENS1 INPD VREF 0
    VSENS2 VREF INMD 0
    R010 VSUM 0 10e3
    *Gain scaling
    R020 VGAINOUT 0 1e9
    *Slewing circuit
    C010 VSLEW 0 10e-12
    R040 VPRE 0 20
    C050 VPRE 0 442e-12
    R099 OUTP FBKP 9500
    R098 OUTM FBKM 9500
    *supply current
    .ends
