  2. PSpice
  3. When create new simulation files,it shows "cannot initialize...
  • Subscribers 32
  • Views 3765
When create new simulation files,it shows "cannot initialize profile"
ZL202412177242
ZL202412177242 over 1 year ago
When I simulated with cadence, I suddenly failed to create new simulation files. It was possible before.Because I used the tsmc 0.18um cmos process library, and the simulation kept reporting errors. I kept trying to modify, but the result suddenly failed to simulate.
  • rg13
    0 rg13 over 1 year ago
    For this error (ORCOMMN-2302): cannot initialize profile. Select File > Exit to close Capture and PSpice application (if running).
    b. Go to Windows Task Manager by pressing CTRL + ALT + DELETE and selecting Task Manager.
    c. In Windows Task Manager, select Processes and click the Image name to sort the processes alphabetically.
    d. Kill the following processes in Task Manager
    o capture.exe
    o cdsMsgServer.exe
    o cdsNameServer.exe
    o MrkSrvr.exe
    o pspice.exe
    o pspiceexplorersrvr.exe
    o simmgr.exe
    o simsrvr.exe
    Now open project in capture and see if you are able to create new sim profile or not?
  • RJ20251230269
    0 RJ20251230269 over 1 year ago
    The issue you're encountering could be related to how the TSMC 0.18um CMOS process library is configured in your Cadence setup, or it might stem from a corrupted profile. I recommend verifying the library paths, ensuring all environment variables are correctly set, and checking for compatibility updates with your Cadence version. Sometimes, clearing temporary files or starting with a fresh simulation profile can help resolve initialization issues.
