  2. PSpice
  3. Getting Error ORPSIM-15108 on trying to simulate my pro...
  • State Suggested Answer
  • Answers 1
  • Subscribers 31
  • Views 3421
Getting Error ORPSIM-15108 on trying to simulate my project
GR202506302211
GR202506302211 over 1 year ago
Hello
I'm trying to simulate a circuit with Orcad Capture CIS (30 day tryal version) and the part AD8250.
I imported the AD8250 Spice model from the .cir file and created the .olb file
I was able to place the AD8250 part but i already have this drc:
"WARNING(ORCAP-2445): Instance U4: SCHEMATIC1, PAGE1 (2.20, 4.00). not found in the configured libraries"
Then if i try to run a simulation then i have this error:
"ERROR(ORPSIM-15108): Subcircuit AD8250 used by X_U4 is undefined"
I tryed to follow the steps below without success:
Troubleshooting OrCAD Capture PSpice Simulation Flow Errors
The AD8250.ind was generated so it should not be a write access permission issue
Any ideas to solve that ?
  • rg13
    rg13 over 1 year ago +1 suggested
    Seems, it is not able to detect the PSpice library from where this model is referenced. In Capture, choose PSpice — Edit Simulation Profile . Select the Configuration Files tab and then select Library…
  • rg13
    0 rg13 over 1 year ago
    In Capture, choose PSpice — Edit Simulation Profile. Select the Configuration Files tab and then select Library. Browse to the location where the model is saved and click either Add to Design or Add to Profile. Click OK.
    For more details on this error and its solution, you can refer following useful article link:
    Article (20484535) Title: Getting Error ORPSIM-15108 on trying to simulate my project
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006DdbOUAS
