  3. SysCap – Tip of the Week: Making Wire Connection
  • Subscribers 27
  • Views 5847
DesignTech
DesignTech over 2 years ago
The Draw Stubs option in System Capture lets you quickly make wiring connections. Refer to our earlier post here.
You can use Selection Filter along with the Draw Stubs option to draw wires on the required component pins.
Turn off the All Objects filter and choose Pin in Selection Filter. Select the required component pins, right-click, and select Draw Stubs.
Selection Filter
If you choose the Draw Stubs > Same As Pin Name option, System Capture will assign net names as per the components’ pin names. You can rename these net names by selecting the nets and choosing the Rename option. A pervious post covers this in detail.
Rename signals
Team DesignTech
Cadence Design Systems
