  2. Adams Car
  3. A/Explore not compatible with Office 365?
  • Subscribers 1
  • Views 0
GMatrang
GMatrang over 8 years ago
Dear all,
while using A/Explore 2017.2 I have a problem, probalby caused by the fact the I use Office 365. Shortly:
1) I generate a Workbook from an Adams/Car model
2) I open the excel file and save it again without no change
3) I import the workbook for the open model
In doing that I have the following message:
Opening XLSX-File: C:/Adams/temp/office_365/test_export.xlsxERROR: ---------------------------------------------------------------------
ERROR: <type 'exceptions.TypeError'>: __init__() got an unexpected keyword argument '{schemas.microsoft.com/.../revision}uid'
ERROR: The execution of the following python command failed:
ERROR: ws_model=wb['Model']
ERROR:
ERROR: Import aborted!
Using a stand-alone version of Excel doesn't bring to any problem...
I didn't find any trace of incompatibility with Office 365 in the release guide, so I don't know if it's an issue or if I have to set Adams or Excel in a particular way to make it work.
Does anyone already had/solved the issue?
Many thanks in advance,
Giuseppe.
  • jozef.bucha
    0 jozef.bucha over 8 years ago
    Hello Giuseppe,
    I tried it using office365 (2016) and Adams 2018, it is working for me without problem. I was using working dir for saving .xls file
    Jozef
  • GMatrang
    0 GMatrang over 8 years ago
    Hi Jozef,
    thanks for the reply. So, it seems the issue is part of the "Resolved Issue" altough I could not find it in the Release docs.
    Many thanks,
    Giuseppe
