  2. Adams Car
  3. SPMM testrig and chassis templates with a Flex-body are...
  • Replies 8
  • Subscribers 1
  • Views 3
SPMM testrig and chassis templates with a Flex-body are generating an error.
burford.john
burford.john over 7 years ago
I've replaced the ges_chassis body with a flex-body and run the assembly on the SPMM testrig. This generates an error.
Reading in property files...
Reading of property files completed.
Setting up vehicle assembly for SPMM...
ERROR:  ---------------------------------------------------------------------
ERROR:  Error detected on line number 316, character 139 of the macro '.ACAR.macros.mac_ana_ful_spm_sub'.
ERROR:   "adams_id" is neither a field in nor a child of ""
ERROR:     (eval("control/routine=acarSDM::con952,function=user(952,"//.F98_spmm_01.testrig.cis_body_subsystem[2].cm.<<adams_id>>//",3,4,5)"))
ERROR:  The command was not executed.
ERROR:  +2&>           (eval("control/routine=acarSDM::con952,function=user(952,"//.F98_spmm_01.testrig.cis_body_subsystem[2].cm.adams_id//",3,4,5)")), &
This error appears to be common to all chassis templates in acar_shared and acar_concept databases when run on the SPMM testrig with the ges_chassis part replaced with a Flex-body except for _flex_chassis.tpl.
Has anyone generated a procedure or script to apply the entities in _flex_chassis.tpl to a standard chassis template like _rigid_chassis_bof.tpl ?
Any suggests would be appreciated.
  • burford.john
    0 burford.john over 7 years ago
    And I'm doing the Rigid to Flex in Standard interface (not in template builder).
  • jozef.bucha
    0 jozef.bucha over 7 years ago
    i will check aero forces, what i was ​trying to say that after replacing rigid to flexible in rigid_chassis template the vehicle was able to run maneveurs, only spmm was not possible. after modification of communicator, spmm was also ok. My modification where pure in template level.
    Do you have knowledge why spmm needs one more communicator in case of flexible chassis and rigid chassis not?
  • burford.john
    The submission macro searches for "flexible_body" to change a hidden parameter value from 0 to 1. That turns on and off a group of entities that changes how the SPMM testrig connects to the ges_chassis body. There must be some other thing happening as well that is causing my problem. I was able to get the model to partically run quasi-statics by turning the solver stablity factor up to "1" usually this is 1E-4. What I could see is the steering system moving as if the motion to lock the steering was not connected.
