  2. Adams Car
  3. How to create jprim in wheel template as in handling_tire...
  • Replies 9
  • Subscribers 1
  • Views 1
How to create jprim in wheel template as in handling_tire.tpl?
jozef.bucha
jozef.bucha over 5 years ago
Hello i am trying to make wheel templte similiar as handling tire. Everything works fine, also jprim I am able to make, but how is this done?
Created forces elements ti[lr]_wheel has attached jprim:
Object Name : ._handling_tire.til_wheelObject Type : ac_tire
Parent Type : Model
Location : (LOC_RELATIVE_TO({0, 0, 0}, ._handling_tire.ground.origo)) mm, mm, mm
Orientation : (ORI_RELATIVE_TO({0, 0, 0}, ._handling_tire.ground.origo)) deg
General Parameters:
property_file (mdids://acar_shared/tires.tbl/mdi_tire01.tir (._handling_tire.til_wheel.property_file_list[._handling_tire.til_wheel.property_file_index]))
property_file_list (mdids://acar_shared/tires.tbl/mdi_tire01.tir)
property_file_index (1)
contact_type (handling)
configuration (single)
outside_tire (no value)
jprim_id (0.0 (._handling_tire.jolper_sse_jprim.adams_id))
center_offset (0.0)
high_performance (0 ("no" == "yes" ? 1 : 0))
Input Parameters:
i_marker (._handling_tire.whl_wheel.tire_i)
j_fmarker (._handling_tire.ground.FMA_1)
ref_marker (._handling_tire.ground.til_tire_ref_1)
Output Parameters:
None
How can I do such thing? I believe answer is in command navigator, but i am not able to find needed command
Jozef
  • MK202610123211
    0 MK202610123211 over 5 years ago
    How about using the original as an example ?
    When I neeed to model things, I always have a look into exsiting templates.
    In this case its a simple aview command:
    constraint create primitive_joint perpendicular &
      jprim_name = ._handling_tire_single.josper_sse_jprim &
      i_marker_name = ._handling_tire_single.ground.jxs_joint_i_1 &
      j_marker_name = ._handling_tire_single.mts_suspension_mount.jxs_joint_j_1
    And then I have an even better proposal:
    If I'm about to base any of my templates upon MSC stuff, I do not copy and modify that anymore.
    Instead I create a command file that opens the original template, carries out my modifications (including deleting stuff that I don't like) and then save it to my private workspace.
    This ensures that I can re-run that procedure in every new ADAMS version and I'll rarely run into the usual isse that MSC changed something in their tire that I have to correct in my private template, too.
  • jozef.bucha
    0 jozef.bucha over 5 years ago
    Thanks for response, i do not have problem with jprim creation itself, i am wondering how that jprim was included in til_wheel, tir_wheel, so it can be activated as needed.
    Jozef
    Dňa po 14. 12. 2020, 11:42 MSC Community napísal(a):
  • Jesper Slattengren
    0 Jesper Slattengren over 5 years ago
    Are you talking about how you can make a jprim that is active during static and then deactivated during the dynamic run?
  • jozef.bucha
    Yes, about that. If I create wheel part and compare to handling tire template, difference is that in handling tire from acar_shared database info about ti[lr]_wheel from force elements in tree shows
    Parent Type : Model
    General Parameters:
    center_offset (0.0)
    The bold line i think is somehow parametrised to jprim that is activated during static analysis and deactivated during dynamic run.
    In Adm 740 is tutorial how to create wheel, but without jprim, it only mention that template from acar_shared database has it (jprim) and why it has.
    I was looking to old forum, but for several days i can not reach that page.
    Thanks Jozef
    I am pretty sure that this jprim_id variables from the different wheels are put into an array during assembly.
    So looking at the acf-file, it starts with registering the different tires
    control/routine=abgTire::con901,func=user(901,1017,99,105,1,2)
    control/routine=abgTire::con901,func=user(901,1025,100,106,1,4)
    control/routine=abgTire::con901,func=user(901,1035,110,116,1,6)
    control/routine=abgTire::con901,func=user(901,1043,111,117,1,8)
    output/nosep
    control/routine=abgVDM::EventInit, function=user(5,1,8,0,3,6,8,17)
    control/routine=abgVDM::EventRunAll, function=user(0)
    If we focus on the first tire, front left, it references ARRAY/1017. Looking at that we see that element 14 is the id of that jprim. This is how the information is passed to CONSUB.
    !Input array for A/Tire in A/Car and A/Chassis
    ! p1 : id of ARRAY holding tire states
    ! p2 : number of tire states
    ! p3 : Side flag (0=left, 1=right)
    ! p4 : id of STRING statement holding role
    ! p5 : id of STRING statement holding tire property file name.
    ! p6 : id of STRING statement holding simulation name
    ! p7 : id of STRING statement holding road property file name.
    ! p8 : id of STRING statement holding contact type (HANDLING/DURABILITY)
    ! p9 : Tire radius for suspension analysis when a rigid wheel is used.
    ! p10: id DIFF for sss, ssc, mmm analyses.
    ! p11: ISWITCH (0=static tire, 1=dynamic tire), if < 0 default: 1=dynamic
    ! p12: id of ARRAY holding scaling and drift factors
    ! p13: id of ARRAY holding user parameters.
    ! p14: id of jprim to lock wheel rotation (for steady state analysis).
    ! p15: RigK
    ! p16: initial speed
    ! p17: id of ARRAY holding doe parameters if applied
    ! p18: id of wheel part
    ! p19: tire load approximation (negative value to turn off ghost force)
    ! p20: high performance switch (0=off, 1=on)
    ! p21: origo marker of the model
    ! p22: id of ARRAY holding fmu road variable ids
    !       adams_view_name='TR_Front_Tires.til_wheel.input_array'
    ARRAY/1017
    , IC
    , SIZE = 22
    , NUMBERS = 1016, 2, 0, 84, 85, 88, 86, 87, 326, 0, -1, 1018, 1019, 6, 0, 0, 0
    , 99, 0, 0, 836, 1021
