  2. Adams Car
  3. Linking ADAMS/Car with ADAMS/View
  • Replies 12
  • Subscribers 1
  • Views 669
jsph_inc
jsph_inc over 2 years ago
Hi All,
Apologies if this has already been documented or discussed. I did a search but did not find anything on the topic.
What is the method(s) to link an ADAMS/Car model with an ADAMS/View model?
The only way I can think of is bringing both into Simulink and performing a cosimulation.
Is there a direct way within the ADAMS environment of doing this?
joe.
  • Rishikesh Mokashi
    0 Rishikesh Mokashi over 2 years ago
    Hi Joe
    FMU is the best approach here. Here is an example :
    Article Detail (hexagon.com)
    Here differential is modeled using Adams/Machinery in View and a full vehicle model in Adams/Car.
    Rishi
  • jsph_inc
    0 jsph_inc over 2 years ago
    Thank-you Rishi! Will review. joe.
  • Jesper Slattengren
    0 Jesper Slattengren over 2 years ago
    It's not ideal to co-simulate a mechanical system coupling in this way. Hopefully it will work, but there is a chance that the discretization of the coupling makes the system unstable. (But yes, FMU is the best way to do it for co-simulation; don't involve Simulink).
    The other alternative is to create a template of your View model. The only downside I can see is that A/Machinery bearings are not supported in Car yet.
    There are a few different ways to do it, but this is should work.
    Save your View model as a cmd file.
    Open A/Car template builder and create a new empty template. Save this. Edit the cmd file and remove the model create statement. Then search and replace all instances of the model name with the name of the template. Now you should be able to import this modified cmd into your template. Then go ahead and setup your communicators to work with the rest of your model.
  • jsph_inc
    Thanks JSlat..I will try the FMU method.
    I'm trying to run the example model from the link above.
    When I try to solve the load case in ADAMS/Car I get the following error:
    ---- START: ERROR ----
    The initialization of ESL test2_open_diff_fmu fails.
    ID = 8
    ---- END: ERROR ----
    I am using ADAMS version 2022.2
    Any ideas about why this error occurs?
    joe.
    I don't even know what state the FMU import/export was in that old version. Try a later version.
    Another possibility is that the FMU can't check out Adams licenses. The FMU will run in its own process and will take a full set of licenses.
