  2. Adams Car
  3. Linking ADAMS/Car with ADAMS/View
  • Replies 12
  • Subscribers 1
  • Views 15
jsph_inc
jsph_inc over 2 years ago
Hi All,
Apologies if this has already been documented or discussed. I did a search but did not find anything on the topic.
What is the method(s) to link an ADAMS/Car model with an ADAMS/View model?
The only way I can think of is bringing both into Simulink and performing a cosimulation.
Is there a direct way within the ADAMS environment of doing this?
joe.
  • jsph_inc
    0 jsph_inc over 2 years ago
    Thanks for the quick response. OK will test this out thanks. joe.
  • jsph_inc
    I was able to solve the example in the link above.
    In reviewing the results I see the full set of A/Car outputs but very limited results for the A/View model (and only when I import the results into the A/View model). I only see some A/View joint forces.
    I tried different output settings in A/View and A/Car for this but didn't seem to help.
    Is there a way to write out and view the full set of A/View results for the process in this example ... including graphic results of the A/View model?
    thanks for any help,
    joe.
  • Jesper Slattengren
    0 Jesper Slattengren over 2 years ago
    OK, so you used the FMU approach. So you will get all the results from the Car model. And you have found the results file from the unpacked FMU for the View model. Correct?
    Well, you have to define in the View model what outputs you want. Results, graphics and request files. Adams/View does not automatically create requests for all elements in the way Car does it, so you have to define all requests manually in the View model.
    You will never be able to animate both models at the same time, at least not in Adams PPT (well you could load both models, bit results or graphics files and animate in separate views).
    Was the simulation successful? No strange discretization problem? Stable results?
    One thing I'm currently working on is stability of co-simulations and that includes FMU connections. So we are very interested in what you are doing. Anything you can tell us can help us create a better interface in Adams.
  • jsph_inc
    Thanks JSlat ....problem solved. I didn't realized the ADAMS/View result files are written to the folder <working_directory>\fmu\test\resources. That's what I was looking for as I was just seeing the A/Car result files.
    The example model solved with no strange results..though this was just a rerun of the MSC example model.
    Will likely use this FMU method so I can keep you posted on any suggestions.
    thanks again,
    joe.
    Much appreciated.
